Rear Camber kit
Old Nov 26, 2002
DizWikedCivic's Avatar
Rear Camber kit
how do u know what degree to adjust your camber kit? if my rear is like lower 2.5 " what degree do i set the camber kit?
Old Nov 26, 2002
andyman97's Avatar
Turbo Guru
keep it at the same specs as it was before...alignment shops should have the specs, or even Honda service
Old Nov 26, 2002
VNlilMAN's Avatar
The Standard One
about -.45 +- .8 degree
Old Nov 28, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
definately recommend a alignment after a drop, no need to guess on camber angle, they will adjust it where it needs to be. You need the alignment anyway, so it might as well be a precision adjustment on the camber
GolNat
Jan 12, 2021 09:06 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
chrisjackson321
Jul 12, 2015 03:00 PM
