Question on bumpstops
Old Nov 26, 2002
MadDem13's Avatar
MadDem13 is an unknown quantity at this point
I am having neuspeed sports put on my 01 coupe today. The instructions call for cutting the rear bump stops. The guy at the shop told me that cutting the bump stops would only make my struts wear out sooner and would not affect ride height. Is this true? Obviously, I would like the wheel gap to be as even as possible all the way around... Will not cutting the bump stops cause an uneven drop?
Old Nov 26, 2002
orso's Avatar
orso is an unknown quantity at this point
Cutting the bump stops will not affect the drop. the purpose is to keep you from bottoming out so much. it gives the shock a little more travel. but yes it will make your shock wear quicker. IMO when you get new springs you should get the konis. the stock suck. i blew mine two weeks after i put mine on.
Old Nov 26, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: orso
but yes it will make your shock wear quicker.[hr]
thats only true if your bottoming out with the full bumpstops. but whats worse, blown shocks or a messed up ride and back? i'd rather have more shock travel then bottom out all the time and save the shocks
Old Nov 27, 2002
SpecV's Avatar
SpecV is an unknown quantity at this point
Honestly if you don't cut the bumpstops you will most likely end up with a very bouncy ride. Depending on how low you go the bumpstop may need to be cut in order for the strut to retrect as far as it needs to.
Old Nov 27, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: SpecV
Honestly if you don't cut the bumpstops you will most likely end up with a very bouncy ride.[hr]
not really...
Old Nov 27, 2002
andyman97's Avatar
Turbo Guru
Yeah, not bouncy, more like bumpy...you'll bottom out alot easier when you hit bumps, potholes, etc. I noticed a difference before and after...I put my springs on without trimming them and it was very bumpy, then I trimmed them, and I noticed a difference when I hit bumps.
Old Nov 28, 2002
SpecV's Avatar
Quote
[hr]Originally posted by: VNlilMAN
Quote
not really...[hr]
The reason I say that is that if you go say 3.5 inches lower the strut compresses as much as it can but the urethane bumpstops can't compress as much as they need to. Therefore you are riding on your bumpstop which will cause a bouncy ride.
Old Nov 28, 2002
VNlilMAN's Avatar
The Standard One
ya true, cause as you said, you'll be riding on your bumpstops. but were talking about a 1.75" drop here... its not low enough so that you'll be hitting your bumpstop on every little crack/rock on the road. its going to take some hard hits for it to compress that far.
Old Jan 22, 2003
flotsamm's Avatar
Bubbling this up..
For those who trimmed your front bumpstops, what did you use to hold them up on top of the strut piston? I trimmed mine, but they dont stay up on top. I assume its fine, but the dust cover isnt functional anymore since it doesnt cover the piston area. Thanks for any replies!
Old Jan 22, 2003
VNlilMAN's Avatar
The Standard One
damn this is old..
Old Jan 22, 2003
flotsamm's Avatar
Yeah.. but was the most recent bumpstop thread I could find without starting a new thread.
I'm thinking of just taking some zip ties and zip them up top... what do ya think? Anybody?
Old Jan 22, 2003
VNlilMAN's Avatar
The Standard One
ya thats sounds like it would work.. just make sure it doesnt get in the way of anything..or maybe glue? but then thats permanent.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
