Sway bar need tie bar ??
Finding some conflicting ideas from searching, so if I get a thicker sway bar, is it necessary to get a tie bar in there? Or does a tie bar merely stiffens it out more?
I'm getting a RSX S sway bar sent to me, and if I need to will get a Tenzo R tie bar...
I read somewhere here that if you get a rear anti sway bar over 20mm it's recommended to get a tie bar so that you don't damage the crossmember and/or rip your subframe. I have a 22mm rear anti sway bar and handling is intensly easier as there is not enough body roll to complain about at fast speeds or notice at low speeds. I don't have a rear tie bar (it's ordered and it's delivery is 2 days LATE!!!!! [IMG]i/expressions/face-icon-small-mad.gif[/IMG])
I like the design of the Neuspeed rear tie bar... as far as I know, it's the only one that doesn't bend.
Quote
[hr]Originally posted by: NBPCivic
I didn't think the nuespeed rear tie bar was out, where did you find it?[hr]
Quote
[hr]Originally posted by: SoNiCcIvIc
I like the design of the Neuspeed rear tie bar... as far as I know, it's the only one that doesn't bend.[hr]
Raiool
Oct 1, 2015 10:42 AM
