What would cause this? (with pic)
Old Oct 13, 2002
Bulletboy's Avatar
Bulletboy is an unknown quantity at this point
I had my Skunk2 coilovers installed at a shop about a month ago. Last night I was going to put on the camber kit and I found some damage to the threaded sleeve of the coilover. What would cause the spring to rub the sleeve?
btw - this is the driver's side rear and the passenger side is not as bad. The fronts are fine.
Old Oct 13, 2002
VNlilMAN's Avatar
The Standard One
ouch.. maybe the springs rubbing against the threads? i have no idea... try calling skunk2 or something. i would guess someone installed it wrong tho. is the thread thing centered or is it tilted inside the spring?
Old Oct 13, 2002
Bulletboy's Avatar
I looks centered from the angle I can see it from.
Old Oct 14, 2002
aZnVoYCe's Avatar
Dang, you lost major thread! Yeah, try calling Skunk2 might be a manufacture defect or something. I don't know the cause but it's really wierd...
Old Oct 14, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
ewwwww that is some serious damage .....call skunk up for sure or the place that installed the springs because obviously something wasn't done properly
Old Oct 14, 2002
WorldsSlowestEm2's Avatar
Sorry to hear man. Id call Skunk2 and see if its a defect, if not, go back to where you got them installed, maybe they'd be able to help
Old Oct 14, 2002
Bulletboy's Avatar
I went to the shop that installed them today and the guys there were cool about it. They are replacing them tomorrow for free.
(They are going to see why the coilovers failed first and go from there)
Old Oct 14, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
hey man my skunk2 coilovers do that too especially on the back jsut like urs. it is front ur camber.
Old Oct 17, 2002
Bulletboy's Avatar
The problem has been fixed. The Skunk2 spring is 1/2" in diameter smaller than the stock spring, so they added a rubber spring cap to the top of spring. The spring is now in place and there to stay.
BTW - Skunk2 is aware of the problem and is sending the caps when needed.
GolNat
Nov 27, 2018 03:32 PM
ricer_em2
May 11, 2016 08:09 PM
thatcham
Sep 30, 2015 08:28 AM
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
