oem part?
Old Nov 4, 2002
  #31
CapYoda's Avatar
Escaped Convict
resurfaced due to current interest level.
and er... hmm. still thinking if I want to do this or not. I hate drilling.
Old Nov 4, 2002
  #32
slikor's Avatar
slikor is an unknown quantity at this point
hmmm...this is very interesting, but would a lower front strut tie bar do the same if not more than this? granted they are like $170 for the Neuspeed one, but i dont wanna drill [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 4, 2002
  #33
Grey's Avatar
DIY King
The drilling isn't that bad really... The 2002's have a hole in that location, so it's not like you'de be doing something that would harm the chassis. Tapping isn't that bad either. If you don't have the proper tools for drilling, then you shouldn't start this little project. Hell, if I had an extra long drill bit of the right size, then it would be much much easier. Simply snake it through from the top and drill out the hole. Piece of cake.
I'm not sure if a tie bar does the same thing. Well, actually... It doesn't. It ties together a different part of the chassis, so it eliminates flex in a different spot. I'll eventually get a front tie bar, so I'm planning to have both. I doubt that I'll be able to feel the front tie bar as much as I did this thing; simply because Honda chose to put it on the 2002's. They saw a problem with the 2001's and they fixed it. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 5, 2002
  #34
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
It looks to me like there are two versions of this bar. One is for the automatics and one is for the manual transmission vehicles. I ordered the Front Sub-Frame from a 2002 EX Coupe for my 2001 EX Coupe.
The bent bar is designed for the Manual transmission cars and the straight bar is for the Automatic transmission cars according to http:www.hondaautomotiveparts.com.
TJ
Old Apr 17, 2003
  #35
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
ok, I think I'll finally order that piece.
...and I discovered that #10 is for cars w/ AT, #11 for cars w/ MT
Old Jul 29, 2003
  #36
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
has anyone installed the torsion bar on their 2001 civic using only the ONE bolt supplied instead of 2 ?.
Old Feb 8, 2004
  #37
marc-111's Avatar
marc-111 is an unknown quantity at this point
that is the frame where you engine supports are placed
Old Feb 9, 2004
  #38
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
I did. Couldn't be bothered with the second hole. But already I could feel the ride improvement with just one bolt per side. Some of my friends are dead certain this has more gains than the upper front strut bar of any make ! Furthermore, Honda can't go wrong with this one.
Old Jun 7, 2004
  #39
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
Has anyone done this on an EX with a after market header? This doesn't interfere anything else does it?
Old Jun 7, 2004
  #40
Zzyzx's Avatar
Autocross Junky
^^ it goes behind the engine, Its no where near the Headder.
Old Sep 14, 2004
  #41
zachgeyer's Avatar
too much $$$$$$$$$$$$$$
Erndog81
Oct 31, 2015 03:01 PM
vtecbrah
19
Jun 5, 2015 09:38 PM
juror
May 26, 2015 06:35 PM
bsmiley
Apr 27, 2015 01:27 PM
