rear camber popping
Yeah I lowered my ride the other week, and just yesterday i heard a popping or creeking coming from the top control arm on the left and right rear. i am trying to figure out what the hell is going on. if anyone could help us that would be great. if i hear anything (no pun intended) i will write back asap).
cool..i had that problem with the front but i fixed it by tighten the big nut(just 1) on the top of the strut tower(under the hood),i think the back needs to be tighten as well.do that with the car on the ground.
The Standard One
if what 1955 doesnt work then read this... my springs knocking? read silver2002's posts.. he talks about the rubber peice in the upper perch isn't aligned right.. also you should have put the rubber tubing that came with your stock springs that goes where your springs sit on the bottom perch
juror
Suspension DIY
Jul 30, 2019 03:28 AM
