want to lower, but worry about handling
Old Sep 7, 2002
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
hey i'm thinking of getting new springs for the car, what type of spring do you guys prefer? i dont want it too low and scratch cause that would suck so bad. and also i heard once the car is lowered, handling will become a problem and will bounce alot. any experienced driver out there can give me some tips
Old Sep 7, 2002
Assasin's Avatar
Assasin is an unknown quantity at this point
when ur car is lowered handling is great. my sedan was like a inch off the ground and boy oh boy did i love that.
Old Sep 7, 2002
1955's Avatar
just springs alone will be okay,only time it bounces is goin over bumps and uneven road but most benefit u will gain is the lowered look and better handling,car will make more controlable turns and more stable on high speed due to lower center of gravity(less air pass thru the bottom).H&R sport spring is just over $170 from tirerack.com.follow the instruction listed from one of our member and u cant go wrong to do it urself,hint.. u need to have more than just basic knowlege of skill in mechanical,good luck.
Old Sep 8, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Quote
[hr]Originally posted by: iluvbritney
hey i'm thinking of getting new springs for the car, what type of spring do you guys prefer? i dont want it too low and scratch cause that would suck so bad. and also i heard once the car is lowered, handling will become a problem and will bounce alot. any experienced driver out there can give me some tips[hr]
The car bounces a lot because most likely the stock struts are blown out. Invest in some good aftermarket struts (for example Koni) if you're going to lower the car. Handling actually improves if you lower your car, due to the lower center of gravity. However, a lower car will ride a bit harsher because the new springs/coilovers have a higher spring rate (stiffer) and there is less suspension travel.
Old Sep 8, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
he is correct lowering the center of gravity of a car efficently improves handlings, hince the car is lower you have less body roll when in turns, strut bar is highly recommended IMHO because the car feels sloppy with springs and no strut[IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Sep 8, 2002
so a good strut bar, and what brand spring? do i need adjustable ones?
Old Sep 8, 2002
Assasin's Avatar
i have adjustable coilovers on mine and ive used it to raise it like well my car was hella low and i got new rims so i raised it a little and then when i got a body kit i raised it a little and then i raised it a little again so yea i love coilovers
Old Sep 8, 2002
Quote
so a good strut bar, and what brand spring? do i need adjustable ones?[hr]
I like coilovers (adjustable springs) because I can lower the car to exactly the level I want. With regular lowering springs, you're pretty much stuck with whatever drop the springs give you (most lower springs lower the front more than the rear). Eibach springs are pretty high quality. Ground Control makes a set of adjustable coilovers that feature Eibach springs (which is what I use).
On the other hand, you can buy a true coilover setup which includes both the adjustable springs and the struts in one package (as opposed to buying them separately). Tein and JIC are two companies that make them for our cars.
Old Sep 8, 2002
Voiceofid's Avatar
End Bringer
i got the neuspeed sports, it made the steering wheel easier to steer and i can take coners really sharp, unlike my friend's intrax springs, his are really bounce, mine rarely bounce compare to his.
note to that is i scrape speed bumps if i got faster than 5mph, and badly constructed roads are not your friend. most of the scraping is the exhaust, though.
it's so low now(in my opinion) i would've returned them if i got neuspeed race
Old Sep 8, 2002
VNlilMAN's Avatar
The Standard One
your main concern shouldnt be what brand. it should be how low. basically what are you looking for? are you looking for performanc, just to kill fender gap or you want the slammed look? of course no one wants to scrape. but this also depends on your environment and how you drive. are you willing to drive more cautiously? also are you willing to spend money on a camber kit and aftermarket shocks?
Old Sep 9, 2002
you're right, i'm not looking for performance, i'm looking to fill up the gap and have a better handling. so what brand we looking for?
Old Sep 9, 2002
TOOLOWCIVIC's Avatar
Once you lower your car it will never ride as smooth as it used too. It will bounce more even if you buy konis only because the springs and shock are too damn stiff. It will ride good on good roads but suck on bad bumpy roads.
Old Sep 9, 2002
VNlilMAN's Avatar
The Standard One
anything from neuspeed, H&R, eibach, or goldlines is good. although if you know me i always say neuspeed. thats just the best bang for buck IMO. alot of others however will say eibach but i think that neuspeed is just as good for $50 less... goldlines name isnt as big but their service is the best hands down. their springs are great and are cheap too. H&Rs arent low enough. neuspeed sports, eibach sportlines and goldlines all give about the same drop.
Old Sep 10, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Quote
[hr]Originally posted by: TOOLOWCIVIC
Once you lower your car it will never ride as smooth as it used too. It will bounce more even if you buy konis only because the springs and shock are too damn stiff. It will ride good on good roads but suck on bad bumpy roads.[hr]
Agreed. Handling is improved. Bouncing is due to the length/softness of the stock shocks.
Koni's are great, but on broken roads or roads with lotsa holes you'll still feel it.
Bottom line, no upgrade can make the stock ride more comfortable, which means nothing can make modded suspensions ride better than stock. If you drop it, expect to lose the comfy stock ride. The only one thing you can do is a Prokit drop (1"), Eibach claims those springs ride exactly the same as stock. I have Sportlines which is one step lower, and the ride was very bad over downtown roads and slightly harder than stock now that I have Koni's.
IMO though I think it was well worth the money.
Old Sep 12, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
you'll have to get new SHOCKS eventually not strut bar bro...and your car handles better lowered...if you lower it with springs it prob. wont be very bouncy...coilovers it depends on how much you lower it, i lowered mine to the ground basically. yes it is bouncy but i love it i just need new shocks as we all will someday just me sooner than others.
Old Sep 12, 2002
MSoft's Avatar
Pedrito's right. I've heard from mechanics of snapping strut bars especially on lowered cars. Of coz I'm talking about those $20 Ebay ones, not name brands. Since the car's lowered the strut bar takes a lot more force, not to mention you'd likely start turning much faster, enjoying the lessened body roll, so the crappy strut bars bend if you're lucky, and snaps if you're not.
Definitely don't take a lowered car with crappy strut bars and no upgraded shocks to the tracks... Bye bye hood & engine.
Old Sep 12, 2002
orso's Avatar
orso is an unknown quantity at this point
i would get the eibach prokit its a 1 inch drop and i hardly ever scrap it looks alot better to. i would koni's to because i blew one of my factory struts within 2 weeks.
Old Sep 13, 2002
Stock shocks suck. Mine blew out within the second day that I installed my ground control.
Old Sep 13, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: orso
i would get the eibach prokit its a 1 inch drop and i hardly ever scrap it looks alot better to. i would koni's to because i blew one of my factory struts within 2 weeks.[hr]
i hardly even scrape with neuspeed sports and my shocks are still good after 5 months.
GolNat
Nov 27, 2018 03:32 PM
bowie
Jan 21, 2018 09:29 PM
fvckbg
Oct 20, 2016 07:37 PM
aaronmechanx
Sep 14, 2015 08:45 PM
Jrosa
Sep 14, 2015 08:24 PM
