Eibach Springs
Old Aug 29, 2002
JB's Avatar
JB
JB is an unknown quantity at this point
Eibach Springs
I just bought and had my local shop install some Eibach Sportline Springs 1.6" drop. Now my question is the FRONT seems way to low compared to the back, about and 1" or more of a difference, is this normal because of the engine? Or did they lower it wrong. To my understanding, it is supposed to be lowered the same all the way around. Thanx for the help guys. Ohh yeah, I also bought some TOYO Proxes T1-S Ultra Performance Tires, They ARE SWEET
For products and parts click here
*Note, company is affiliated with NOPI so they can sell parts REALLY cheap.
Old Aug 29, 2002
iloverice's Avatar
iloverice is an unknown quantity at this point
Yeah man mine are like that too... except not like 1"
Old Aug 29, 2002
pounds's Avatar
pounds is an unknown quantity at this point
you just got em put on...they need to settle....
in a couple weeks it should look right....i have sportlines too but the front is a little lower...not too noticeable, you kinda have to expect it tho since the front has to carry the weight of the eingine
no worries, it will work out
Old Aug 29, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
The back of our cars sit a little a higher in the back than the front stock, so I would assume if you dropped the car the same height in front and back that the back will still be just a bit higher.
Old Aug 29, 2002
CarpeDiem's Avatar
CarpeDiem is an unknown quantity at this point
Luv to see some pics...
Old Aug 29, 2002
ThUgGiNAzN's Avatar
ThUgGiNAzN is an unknown quantity at this point
i got eibach sportlines wit a koni and ingalls set up but mah back looks lower then the front cuz i got a 2 finger gap and the front has a 3 finger gap so yea
Old Aug 29, 2002
JB's Avatar
JB
Thanx Guys, now what else should I do to make the ride more stiff and comfortable. What type of shocks, dampers, struts should I get? Too many to choose from. Besides those that I mentioned anything else you think I should get to complete the whole LOWERING process.
Old Aug 29, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
strut bars and maybe a camber kit.
Old Aug 29, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: ThUgGiNAzN
i got eibach sportlines wit a koni and ingalls set up but mah back looks lower then the front cuz i got a 2 finger gap and the front has a 3 finger gap so yea[hr]
are you sure it was the sportlines? maybe it was the prokit?
Quote
[hr]Originally posted by: JB
Thanx Guys, now what else should I do to make the ride more stiff and comfortable. What type of shocks, dampers, struts should I get? Too many to choose from. Besides those that I mentioned anything else you think I should get to complete the whole LOWERING process.[hr]
only ones available now are koni inserts. also get a rear camber kit, dont need the front.
Old Aug 30, 2002
jsmove's Avatar
jsmove is an unknown quantity at this point
I think you just may need to let them settle
Old Aug 30, 2002
ThUgGiNAzN's Avatar
yea they are sportlines i think i juss need to adjust teh konis
Old Sep 10, 2002
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
I have sportlines and they are perfect, a good ride and no difference between front and back
Mad Dog Tannen
Oct 19, 2016 08:12 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Viczhou
Sep 2, 2015 07:55 PM
