my springs knocking?
Old Sep 10, 2002
  #31
Kore's Avatar
Kore is an unknown quantity at this point
I had this problem too... my tie rod boot riped and was making noise..but after i fixed that ..it still made that poping sound...there is an insert that you can add between the spring and the top plate that gives the spring some grip or better sliding.... check it Energy Suspension I'm buying these because that noise is making me crazy! I'll find the answer!
Old Sep 11, 2002
  #32
Club2005's Avatar
Club2005 is an unknown quantity at this point
I have heard to have your knuckle checked out, ball joint & CV boot. my $.02. Mine does it too. Bad... Over bumps, and when turning the wheel.
Old Sep 11, 2002
  #33
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
I got mine fixed no more knocking!! when I took off the strut the top spring mount has maybe 8 tabs hanging down to keep the spring in place, 3 of those were bent down. also the piece that sits inside there (not a bearing but not sure what it is called) it actually rotates is the spring mount, was not sitting in there straight. I dont know what caused the tabs to bend either from the piece not sitting in their straight and the spring popped out causing the tabs to bend or just from the piece not sitting in their right
Old Oct 16, 2002
  #34
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Okay, so here's a strange problem that I've only just now started to hear. I've got Neuspeed Sport springs with Koni shocks. I've installed everything correctly and have had no problems until now. When travelling relatively slow (3-5 mph) over uneven surfaces (i.e. a rough road, not even large bumps) I've got this rumbling/thud sound coming from the front suspension. It's somehow related to the vertical (up and down) travel of the suspension. I'm on my stock tires for now and have checked every joint associated with the front suspension as well as any mounting points, etc. and have found nothing abnormal. My springs are aligned properly as I carefully followed the Honda shop manual for front suspension installation.
I thought it was the top strut nut but it's cranked down tight. I also thought that maybe I had messed up on re-installing all the suspension pieces but NOPE, it's all correct. Everything's torqued to the manual's specifications. It's starting to **** me off because everything was fine until now. I have had no turning noises, no popping, no rattling, etc. but this noise now is really confusing.
Anyone with this particular issue? I'd like to bounce ideas off of someone to try to fix it.
Thank you,
TJ
Old Oct 16, 2002
  #35
VNlilMAN's Avatar
The Standard One
do you have the spring isolator? that should eliminate the noise
Old Oct 17, 2002
  #36
3rdcivic's Avatar
Both the upper rubber spring perch insert and the lower coil sleeve are installed. I actually found what I believe to be the cause of this noise. For some reason, even though everything is perfectly aligned, the upper spring cap/plastic bearing piece are not sitting flat up against the top strut mount. One side is and one is not. It looks like this is caused by the void created by the end of the top coil vs. the next coil.
Anyways, I'm going to drive around for a few days to see if I can get it to settle in properly. Otherwise, I'm going to purchase two new rubber spring perch inserts (as recommended in the Honda shop manual anytime new springs are installed).
TJ
skeener51
Oct 1, 2015 05:56 PM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Styven Szastur
Sep 23, 2015 05:26 PM
TheRiddicles
Sep 21, 2015 01:28 AM
