Am I Sagging?
Old Aug 11, 2002
BiGDoG's Avatar
BiGDoG is on a distinguished road
Am I Sagging?
Hey i got goldline springs on my car and the drop looks very good but my questions is.... how come i have 1 finger gap in the back and 2 fingers in the front? Am i sagging? Thanks
Old Aug 11, 2002
tricky's Avatar
Let's see if I know the ledge
tricky is on a distinguished road
i have the same problem...still not sure what it is, but Jeff from Goldline mailed me a set of sedan springs which have a higher spring rate and he said it should sit even...some peoples look amazing and us have problems so...don't know, i havent got them yet but it should be here in a week or so.
check out the pix i posted and the email i got from goldline if you havent already
Linky
Old Aug 12, 2002
VNlilMAN's Avatar
The Standard One
these are the only complaints i've heard about goldline... but ya hope things get fixed... please keep us posted...
Old Aug 12, 2002
dragoon's Avatar
isn't the front supposed to ride lower than the back anyway? like 1.75 front 1.5 back? and if you just installed them, the springs in the front settle much quicker than the back ones because the engine weighs more.. i didn't have the problem cause i just got my 320lb friend to sit in the back for a couple hours [IMG]i/expressions/laugh2.gif[/IMG]
Old Aug 12, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: dragoon
isn't the front supposed to ride lower than the back anyway? like 1.75 front 1.5 back? and if you just installed them, the springs in the front settle much quicker than the back ones because the engine weighs more.. i didn't have the problem cause i just got my 320lb friend to sit in the back for a couple hours [IMG]i/expressions/laugh2.gif[/IMG][hr]
what BigDogg wrote: "how come i have 1 finger gap in the back and 2 fingers in the front"
Old Aug 14, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
dragoon your wrong, the 1.75 front and 1.5 rear doesnt mean rear should sit lower, means front should sit lower, the rear automatically sits higher from manuf. they do this in the event to even out the drop, if it was 1.75 drop all around i think the a$$ would sag bad?? am i correct[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 14, 2002
hedeci's Avatar
hedeci is an unknown quantity at this point
2 fingers in front 1 in back not big of a deal for me
but it might be couse my subs and amp in the trunk.
Old Aug 14, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
Listen people the Gold-Line springs come with a no sag guarentee. All you people who complain about sagging, uhh lets see it might be because you have speakers in your trunk. I have nothing in my trunk and on even ground, my car sits even eith a 1.75 all the way around and Koni's for the rear. The Gold-Line sticker should face up.
Bill
B&B Performance
Old Aug 14, 2002
GoldLine's Avatar
GoldLine is an unknown quantity at this point
The reason for the difference in fender well gaps front to rear is simply due to the fact that the fender wells are cut higher in the front than in the rear. This is done due to the fact that the front wheels/tires rotate and therefore need additional clearance. We would have to lower the front of the vehicle considerably more to establish an even gap.
Some people however, do want the rake front to rear and that's understandable. We just design those coils to lower the vehicle evenly. Thusly, giving the "appearance" of the rear being lower than the front. Disregard the fender well gaps and you will notice that the vehicle sits quite level.
Old Aug 14, 2002
tricky's Avatar
I took out my subs and amp and it still sagged...but i'm still in the midst of hopefully getting replacement springs from Goldine...
Old Aug 14, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
the rear is deffinetly closer to tires than the front but it does look nice still there is no gap in the rear on mine and the front abour 1.5" we got a lifetime warrantee on it so nothing to worry about.
the car looks even on the floor tho i think its the fender thing that goldline was talking about is acurance because the car isn't no no angle for sure.
Old Aug 14, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: GoldLine
Some people however, do want the rake front to rear and that's understandable. We just design those coils to lower the vehicle evenly. Thusly, giving the "appearance" of the rear being lower than the front. Disregard the fender well gaps and you will notice that the vehicle sits quite level.[hr]
eh.. he might be right. i have a 1 finger gap all around.. if you measure the ground clearance however, the front is an 1" lower then the rear. so i guess if you want an even fender gap go with neuspeed, if you want an even ground clearance go with goldline.
GOLDLINE, you probably dont remember but we had a discussion last time about the spring rates being 300lbs which means for every 300lbs, it compresses 1". but since we have 4 springs, this would mean that the weight is distributed right(it might not be evenly distributed but it still is). so now that we have this info, having a 200 lb system(which is fairly heavy for a system) isnt going to lower the car .6" but only around .25" cause the weight is mainly distibuted among the rear springs.(the .05" would be what the front springs might be "holdling")
bsmiley
Apr 27, 2015 01:27 PM
gearbox
May 9, 2004 10:39 PM
slicksivik
Sep 29, 2003 07:27 AM
AzNxTc
Oct 24, 2002 06:51 PM
asianmatrix02
Jul 2, 2002 12:27 PM
