Attn!!I need to know what the best springs are to get for my Cherrie.......
Subscribesup everyone! I know this must be asked all the time, but i am saving up for my rims, tires, lowering springs and camber kit, and I just need to know what springs you all would recommend... i really appreciate it. Thank You!
I got Eibachs SportLines.... they are cool, but my shocks did blow out not to long after
it will not matter what kind of springs you use for your civic ( unless they dont lower your car ) the shocks will Prob. blow out
No pic. but there are other people with the same set up
Depends on what kind of drop you're looking for. If you're looking to SLAM it, you might be better off getting a set of full/true coilovers, such as the B+G's, but be prepared to pay around $1300. If you're looking for something moderate (1.5-2"), I'd suggest a set of Goldline Springs. I've heard nothing but praise and rave reviews on them, and you can get them from Rob at Tornactive.com (see upper advertisement on screen) for under $150 shipped if I'm not mistaken. If you change your springs, definitely get new shocks. Right now the only option we have is Koni Yellows. They were originally a shock insert to your stock suspension, but from what I understand the full shock replacement has recently been released, so that's probably the better way to go. A camber kit will DEFINITELY be necessary if you're getting anything larger than a 17" rim, but I'd recommend it regardless of rim size or degree of suspension drop. You never can be TOO careful. Ingalls makes a damn good camber kit, and I think there's another company, SPC is it?, that has a good kit as well. All in all, it's all dependent upon your preference. Happy Dropping!
neuspeed, their a reputable company with quality products and the springs are about 40-50 dollars cheaper than eibach on most websites, just make sure they give the right model for your car
