anyone else have this problem?
Old Jul 25, 2002
ucsbcivic's Avatar
ucsbcivic is an unknown quantity at this point
I drive a 2 door 2001 ex civic and i recently bought sprint performance springs for it and got them put on "professionally". The problem is that the back end of my car slouches a little lower than the front, and its enough of a difference to be noticeable. A lot of people that see my car think i cut the springs or heated them up because the car doesnt sit evenly. Did anyone else have this problem with their lowering springs, and does anyone know what the cause/solution is? Thanks to anyone who helps me out.
Old Jul 25, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
It's your strut. The back is sagging on those springs. You'll either need to get new springs (other makes, not sure what type will not sag) or get Koni shocks.
BTW, I remember someone asking what kind of springs have even front and back, my Sportlines do. With Koni's installed, the front and back are quite even... The back is the very slightest higher (less than half an inch, I'll measure it next I'm washing the car or smthg) but not as much as I've seen.
Old Jul 26, 2002
VNlilMAN's Avatar
The Standard One
couple reasons/solutions... the old sprint springs had this problem... they came out with a new one that fixed this... either that or they didn't install it right... its most likely you got the old springs tho.
solution: 1) get different springs. 2) put a "spacer" in the rear like familyguy has. 3) if the front has dead coils, cut one of them off. all three require you to do the installation over again tho...
Old Jul 26, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
Easy fix=Gold-Lines (No sag guarantee)
Old Jul 26, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
Quote
[hr]Originally posted by: AirForce
Easy fix=Gold-Lines (No sag guarantee)[hr]
Exactly, I've heard nothing but good things about Goldline.
Old Jul 26, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
i got the goldlines i got no gap in the rear and in the fron about a 1 finger dont know if it's saggin or not i got the sedan model and the car does look leveled but i also got a box and 2 12's in the back too so i dont know what is up with that
gonna put some 17's on my car next weekend so i'm gonna see if it's noticable .
Old Jul 26, 2002
Its probably that big box in the trunk. I have 17's on my coupe and i have about a 1 1/2 finger gap in the front and a 2 finger gap in the back.
Old Jul 27, 2002
dragoon's Avatar
i use eibachs - you pay for the name, and with good reason, too.
Old Jul 28, 2002
Mbow's Avatar
Neuspeed sports on my sedan. Perfectly even drop the whole way around. I have just over a finger gap at each corner. Great springs....
Old Jul 28, 2002
Bulletboy's Avatar
Bulletboy is an unknown quantity at this point
I just had Intrax Springs put on my car with a 2" front drop and 1.8" drop in the rear and here is what I ended up with...
It is a little uneven, I think. The back looks like it is sagging. What do you think?
Old Jul 28, 2002
MSoft's Avatar
Quote
[hr]Originally posted by: dragoon
i use eibachs - you pay for the name, and with good reason, too.[hr]
Agreed. There must be a reason Eibach decided to do less drop on the 01 Civics. Traditional Pro - 1.4", 01 Civic - 1". Traditional Sportline - 2.0", 01 Civic - 1". Wheras all the other brands just went with their standard drops.
Old Jul 28, 2002
MSoft's Avatar
Quote
[hr]Originally posted by: Bulletboy
It is a little uneven, I think. The back looks like it is sagging. What do you think?[hr]
Yeah, that looks sagged, man.
Old Jul 28, 2002
VNlilMAN's Avatar
The Standard One
Quote
sorry i would have to disagree. eibach springs are only designed for the coupe, meaning the back will be lower then the front on a sedan.
i think neuspeed and goldlines are just as good or even better then eibachs... they are also $50 cheaper. both neuspeed and goldline have recognized that there are people with sedans that want to lower their cars. so they have made a kit for both 2 door and 4 door since the 4 door is heavier in the back...
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
