Fixed Rear Camber Under $1
Old Jul 16, 2002
Desi's Avatar
Desi is an unknown quantity at this point
well, i finally fixed my rear camber today. no i didn't buy the ingalls or spc camber kit. i bought 15 washers from home depot for less than a $1. its hard to explain without pics but i'll try. on the rear camber there are two bolts attaching the camber to the car. all i did was put 3 washers on each bolt (6 per camber) and it worked. its ghetto but it saved me over 100 dollars
i think i'll shell out the 20 bucks to fix the front
Old Jul 16, 2002
zero's Avatar
zero is an unknown quantity at this point
Just remeber that you will have to replace the washers often. they are not that hard so through time they will get pressed and will not be the same size.
Old Jul 16, 2002
nightkids1's Avatar
Initial D!!!!
that actualy works, someone told me about that didnt think it worked
Old Jul 16, 2002
Xudus's Avatar
Xudus is an unknown quantity at this point
Cool, I think Im gonna try that...post pics if you can, and maybe amore detialed DIY
Old Jul 16, 2002
speedracersong's Avatar
Quote
[hr]Originally posted by: zero
Just remeber that you will have to replace the washers often. they are not that hard so through time they will get pressed and will not be the same size.[hr]
i dont think itll be much of a notice if they got pressed right?
very good idea desi
Old Jul 16, 2002
vino's Avatar
vino is an unknown quantity at this point
hmm thats kool....is it safe though?
Old Jul 16, 2002
VNlilMAN's Avatar
The Standard One
ya i've heard it doesnt work on our cars, only the previous gens... but i guess if you did it then it does... i'll look into it tho
Old Jul 16, 2002
Mbow's Avatar
Very nice. However, that is a pretty important part of the suspension back there and I think I will keep my SPC kits. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jul 16, 2002
Grey's Avatar
DIY King
Oh yeah, that will work. The bolts will be a little more strained than before, but it should work. The SPC rear camber kit is the best one out there IMO. I would still get that with the polyurethane bushings. That would be the optimal solution. Expensive, but optimal.
Old Jul 17, 2002
TOOLOWCIVIC's Avatar
I'll just stick to my Eibach.
Old Jul 17, 2002
2cute's Avatar
2cute is an unknown quantity at this point
Please forgive me if I seem like a fool but....
Quote
[hr]on the rear camber there are two bolts attaching the camber to the car[hr]
Now the question is WHAT???????? What the hell is the camber that is attached to the car. The strut is attached to the car. Camber is something that happens to your suspension not something that is attached to your car. Camber in technical terms is the inclination of the steering axis in the longitudinal plane.
Old Jul 17, 2002
VNlilMAN's Avatar
The Standard One
it wasnt a question... i think he meant the control arm...
Old Jul 17, 2002
mohawkboom's Avatar
it can be done...but it's not really safe as the washers can slightly compress and add shear force to the bolt...a solid one one piece ring would work much better
bo_red
Apr 23, 2015 10:09 PM
ayzan
17
Jun 30, 2002 12:36 PM
ayzan
Dec 17, 2001 10:21 PM
ernhole1
Dec 6, 2001 12:05 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
