FOR THOSE WHO THOUGHT AIRSUSPENSION WASN'T OUT FOR OUR CARS
Old Jun 18, 2002
TOOLOWCIVIC's Avatar
It has been out for almost a year now. Check it
Old Jun 18, 2002
I don't know if I should go ahead and get this or wait for ridetechnology to come out with another kit.
Old Jun 19, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
no how much is it for any air crompressor and everything else. will they give a like a group deal when u buy all the parts together it would be cheaper then buying everything seprately.
Old Jun 19, 2002
VNlilMAN's Avatar
The Standard One
ya i saw that on chassis techs site but i heard they weren't a great company, well atleast before they weren't...
Old Jun 19, 2002
Hawk's Avatar
You boost, I-VTEC
oh goooo!!! hhmmmm air bags in a vic. hmmmmm!!
Old Jun 19, 2002
sspem2's Avatar
em2
i no this might sound like a noobie question but what are air struts and compressers ???? i no i no im dumb but i just started this whole import thing so bare wit me 4 right now im learning
Old Jun 19, 2002
Well the compressor will fill up your tank to fill up your struts so you can raise or lower your car whenever you want.
Old Jun 19, 2002
VNlilMAN's Avatar
The Standard One
think of them as hi tech hydrolics. you use air instead of batteries tho. you can make your car hop but air bags really aren't meant to do that... read whosyourdaddy's FAQ about air suspension to know more
Old Jun 19, 2002
bake's Avatar
bake is an unknown quantity at this point
so is that all you need to do air suspension??? if so how much is the install around money wise...ive heard its like anywhere from 1k to 2k for the install, and when u let all the air out of the bags do the wheels camber, ive seen an acura with bags and when he sat it down the wheels did a neg. camber
Old Jun 19, 2002
VNlilMAN's Avatar
The Standard One
i've posted this before but i'll post it again, maybe even include it in whosyourdaddys FAQ. there are a couple ways too hook it up.
4 - air strut/rod/bag $600-1000
air tank $20-60 depending on size
compresser $200-500
pressure switch so pressure inside tank doesn't get too high $25
guages $30-100
lines/fittings $100 depends on size
also you probably want it to work with a switch/button so...
switch $30-100
valves 100 a pop = $400
i think i missed a couple... you could get a slow/cheap setup for like 1500 installed or a fairly fast one for 2200 installed.
Old Jun 23, 2002
bake's Avatar
some questions from the air suspension ignorant...the air tank... what size 2 gal, 3 gal 5 gal, and how many do u need one for each or just one
compressor.... how many psi
lines and fittings...what size and what length
Old Jun 23, 2002
VNlilMAN's Avatar
The Standard One
i've heard it takes 3 gallons to fill 2(or was it 4) bags from lowest point to the highest point. after theres no more air in the tank you have to wait for the compressor to fill it back up again. some take up to 2 mins-5 mins. some people even get 2 compressors. heard you could even use the a/c compressor. oh then there's also the the air compressors that run of one of the belts... i believe what you want to look at is the 'cfm' not sure what it stands for but from what i remember, higher the number, the faster it produces air.
lines+fittings... there's your standard lines and theres also steel braided one(that costs a arm and a leg). theres also the size, 1/4,3/8,1/2. the size also depends on how fast you want your bags.... 1/2 would probably make your car 'hop'(get some air time) if you wanted to... 1/4 might be too slow.
so ya i would recommend 3/8 for the average user... steel braided lines aren't necesary
5 gallon tank or 2-3 gallon
4.0 cfm, 3/4 hp, 2:30mins to fill 3 gallon tank
Old Jun 23, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
Vnlilman, thanks for clearing that up, i was kinded pissed thinking i could have got bags for a g, after paying 1200 for my B&G's
Old Jun 24, 2002
VNlilMAN's Avatar
The Standard One
actually i think you can have air suspension for a g.... i've heard you could just use the bags/rods itself... no tanks, compressors, lines, fittings, etc... it would be hard to adjust but i'm sure its possible. i mean its just air inside the bags/rods. just have air in them and you have air suspension... you just cant adjust it with the switch of a button or anything...
Old Jun 24, 2002
nongv's Avatar
nongv is an unknown quantity at this point
can i installed the setup myself or do i need to bring it to a shop?
Old Jun 24, 2002
From what I was told by people with airrods is that it should be a complete bolt on. Just replace your springs and shocks.
Old Jun 24, 2002
VNlilMAN's Avatar
The Standard One
it depends on the kit, if its made specifically for our cars, chances are its all bolt on.. if your getting one put together then some modifications might be needed. but ya just make sure you know how to wire/connect everything before you actually do it yourself
Old Jun 24, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
CFM = Cubic Feet per Minute
Old Jun 24, 2002
bake's Avatar
well i got all my parts up to alil over 2k and after all that it hit me......where the f*** am i goin to put itall ......i just don't think i can sacrifice my subs for my suspension to put it in the trunk, so as bad *** as it would look i think im goin to go back to some sportlines
Old Jun 24, 2002
VNlilMAN's Avatar
The Standard One
how much room does your subs take up? cause i know i have enough room for two tanks on each side of the box with the compressor chillin somewhere else.... it doesn't take up that much room. n i'm sure it would even fit where the spare goes..
Old Jun 25, 2002
nongv's Avatar
so how big are the compressor and the other stuff that we need?
Old Jun 25, 2002
Compressors come in many different sizes but there is still plenty of room for subs. When I was at the Import Revolution there was a 94 accord that had 4 12 inch subs and had a compressor in there. He also had all his amps and stuff on the sides. You should have plenty of room to put in a compressor and subs. But you can always get a big compressor and tank.
mattdoc
Mar 14, 2017 12:10 PM
alexkharden
Apr 23, 2015 07:13 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Jonas Powell
Apr 16, 2015 11:47 AM
dooner24
Apr 14, 2015 07:51 PM
