lower rear strut bar install.....30 mins, easy!
Old Jun 13, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Thanks to the ppl on this site I got my rear lower strut bar installed in 1/2 hour. At first I was afraid to attempt it myself since the control arm can fall down and is very difficult to get re-aligned so you can get the bolt back in.
The trick is to use a C-clamp to clamp the control arm to the frame so it wont move when you take the bolt out. Super easy install. Just unbolt it, put the strut bar on and bolt it back up.
Old Jun 13, 2002
Spider883's Avatar
9K Redline Owns U
you mean rear lower tie bar.
Old Jun 13, 2002
AlexLx's Avatar
AlexLx is an unknown quantity at this point
i hate it when people try and point out mistakes. everyone knows what he meant
Old Jun 13, 2002
Spider883's Avatar
9K Redline Owns U
some people dont know.
Old Jun 13, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
Quote
[hr]Originally posted by: AlexLx
i hate it when people try and point out mistakes. everyone knows what he meant[hr]
[sarcasm]Yeah, I really hate it too when people correct my mistakes. I never really want to know the right way anyway.[/sarcasm]
Old Jun 14, 2002
andypanda's Avatar
andypanda is an unknown quantity at this point
who gives a sh*t
Old Jun 14, 2002
icey's Avatar
icey is an unknown quantity at this point
Quote
[hr][sarcasm]Yeah, I really hate it too when people correct my mistakes. I never really want to know the right way anyway.[/sarcasm][hr]
*laughs*...OyD...yur hilarious dood!
Old Jun 14, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
post some pics please
Old Jun 14, 2002
slikor's Avatar
slikor is an unknown quantity at this point
excellent! i was concerned that the rear control arms would fall out (and most likely on my face) if i installed the rear lower tie bar, but im glad you've found an easy solution. hopefully soon i can get the bar and install it.
btw, did you just jack the car up when you installed your tie bar, or did you have it up on a lift?
Old Jun 14, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
OK let me just say i feel dumb for not thinking about the C clamp idea.. I did mine without the clamp and it took me about a half hour a side. but the control arm doesnt go down it goes up to the top if you pull the bolt out I recomend taking the tire off because then the weirght of the wheel doesint fight you either and its then easier to move the control arm.
Old Jun 14, 2002
iamfob's Avatar
i got my rear lower tie bar but i havent install it yet...it sounds really hard to install...and i have no experience on any DIY so i am not sure if i should get a shop install for me
Old Jun 14, 2002
Decamo's Avatar
I had it up on jack stands. Its really easy. It'd be foolish to pay someone to do something this easy...... Of course if you'd like to pay me thats another story.
Old Jun 15, 2002
tummyboy's Avatar
its not that bad Iamfob. just take your time and things out and it will go smooth
Old Jun 15, 2002
CIVICMAN67's Avatar
CIVICMAN67 is an unknown quantity at this point
That C-Clamp idea is awesome, I still have my DC Sports one waiting to go on! Now that motivates me to go work on it[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 15, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Anyone got pics of this. I plan on getting a lower tie bar and am going to do the install myself.
Old Jun 16, 2002
iamfob's Avatar
so Decamo andtummyboy, do you recommended i removed the rear tires when i install the rear lower tie bar?
i will try do it myself but i will make sure i call 1 or 2 friends who are experience working under the cars to guide me thru
but i dont understand the C-clamp idea...can someone explained more clearly to me before i started this little DIY
Old Jun 16, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
somebody needs to hook us up with some pictures of the install or even the final product
Old Jun 17, 2002
tummyboy's Avatar
Yeah I defintly recommend removing the tire I did one side of my car with the tire on and one side with it off and the when its off it doesnt fight you as much . The clamp idea is used to hold the swingarm from moving when you pull the bolt out that way you dont have to work as hard to realign the bushings
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] lower strut brace 2.jpg (19 Kb)
Old Jun 19, 2002
Decamo's Avatar
I didn't remove the tire. I just clamped that sucker on tight and took the bolt out. The control arm didn't move a mm.
Your in toronto right? I can help you with the install if you want. I even have the C-clamp.
Old Jun 19, 2002
OyD's Avatar
OyD
It's really easy. I didn't even use a clamp.
All I did was slide a bolt into the hole as the bolt came out the other end. Took only about 15 minutes
Old Jun 20, 2002
iamfob's Avatar
ya i am from Toronto, and i appreciated your help but i dont know when i will do it but for sure it will be before the BBQ meet...i will let you guys know when i will start this and maybe you can give me a hand...thanx
Old Jul 4, 2002
iamfob's Avatar
ok i got my rear lower tie bar installed by my mechanic yesterday...i didnt have time to do it myself and afraid it will fall apart if i take the bolts off...
it makes a small difference but not by a lot
Old Jul 4, 2002
VNlilMAN's Avatar
The Standard One
just wondering how much it cost to get it installed...
Old Jul 6, 2002
iamfob's Avatar
$20 CDN
it took like 10 minutes when the car was in the air...now it's very good and stiff
i like it a lot
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
CapYoda
Nov 11, 2001 05:17 PM
andylao
Nov 4, 2001 01:19 PM
