I need help ASAP please
Old Jun 10, 2002
Alex1's Avatar
ok tonight on my way home right wheel or something there is making noise. its like a squeaking or creaking type of noise. it goes away and then it makes noise again. im scared of accidents so if you guys hae any input on this i would gladly appreciate it. if your going to ask i have my car dropped 2" with stock wheels for about 4 to 5 months now. so its not that case i guess. just tonight it started doing this, but earlier i didnt hear it.
Old Jun 10, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
if you have groundcontrols thats the answer its that and they are to tight
Old Jun 10, 2002
SkiLLzSter's Avatar
illest ma f*cken member
yup...happened to me...i dropped it all the way down the coil tightened it too much and squeeked so i raised it a little and didn' tighten it so tight and no more sound....relief!!!
Old Jun 10, 2002
Alex1's Avatar
no i got progress springs.. i dont have ground controls.
Old Jun 10, 2002
sadboy916's Avatar
maybe its just those springs make the car sit to low if you post this the suspension forum you will get better info
Old Jun 10, 2002
plastic's Avatar
plastic is an unknown quantity at this point
maybe within that time.. the spring got shook up maybe after a big bump or ditch and can't seem to sit right again.. u can try jackin the car up and maybe bang the spring with a soft hammer? [IMG]i/expressions/face-icon-small-confused.gif[/IMG] ..but don't take my word for it, just a suggestion
Old Jun 10, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
Quote
[hr]Originally posted by: plastic
maybe within that time.. the spring got shook up maybe after a big bump or ditch and can't seem to sit right again.. u can try jackin the car up and maybe bang the spring with a soft hammer? [IMG]i/expressions/face-icon-small-confused.gif[/IMG] ..but don't take my word for it, just a suggestion [hr]
This is what happened to my car. I hit a huge bump, and then my car started to make clicking sound when I would turn. It was because the spring wasn't sitting right like alex1 said.
My bad, I mean plastic (alex1 started the thread).
Old Jun 10, 2002
Alex1's Avatar
guys its not that clicking problem with the spring. its like something is hitting the rotor or the wheel as it turns. it dissapears when i step on the brake. other than that its there.
Old Jun 11, 2002
TexazMane's Avatar
TexazMane is an unknown quantity at this point
To me it sounds like ur dust sheild is bent and is rubbing ur rotor..happened to me once ..juss get a rubber hammer and knock it straight...hope that helps
