ground control coilovers - modifications
Old May 24, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
if i install GC coilovers i hear i gotta cut some stuff to make it fit into my 2k2 ....if i do that does that mean it going to affect me putting back my factory springs or changing anything if it's needed???
and does it only work with Koni shocks....or can i use any type of shocks when i replace the factory ones??
Old May 24, 2002
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
you should search before posting bro, if you don't 2 things will happen,
1. you wont get a response back from anyone...or
2. you'll get flamed hardkore...
search and you shall find....
Old May 30, 2002
VNlilMAN's Avatar
The Standard One
if you cut the lower perch on the front then ya you cant put back the stock springs back...
right now only shocks out for our cars are konis. tokicos are supposed to come out soon and those are full strut replacements so you will be able to put your factory springs on those.
since konis use factory struts and you are cutting then you wont be able to factory springs back on...
GolNat
Jan 12, 2021 09:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Dani1993
Jul 24, 2015 09:02 AM
