wheel help
Old Feb 23, 2013
jhill15's Avatar
jhill15 is an unknown quantity at this point
wheel help
Hi all, this is only my second post on this forum and I wish it was on a better note.
A little background 03 civic hybrid 165k
Today I rotated my tires on the grounds in which there was a slight thumping while I was driving. So I criss crossed the wheels driver to passenger front to back. Now the thumping is ten times worse. I checked for wheels baiting fails and lumps and bumps on each tire and everything seems fine. I'm not sure what's going on. Can anyone help
Thanks a bunch everyone
Old Feb 23, 2013
Re: wheel help
You put the noisy tires on the front, now they are much more noticeable.
Old Feb 24, 2013
jhill15's Avatar
Re: wheel help
Will putting the noisy tire on the front work its self out or should I get be tire?
Old Feb 24, 2013
Re: wheel help
Depends.
Depends on what the actual problem is, and how bad the tires are.
If the tread is only choppy on the edges, maybe.
If there is diagonal wear across the face of the tire tread, junk it.
If it is only edge wear:
It might come out if it is only a little bit choppy.
If it is significant, I might put the tires back where they started and swap them side to side instead of front to rear.
Chances are good that they will just stay noisy for the rest of their natural lives too.
If there is decent tread and noise is the only issue, I'd suggest to keep driving and get your moneys worth out of the tires.
Next time
Pick better tread design
Check the wheel alignment
Rotate them regularly
Check this post too:
https://www.civicforums.com/forums/3...ml#post4633601
Old Feb 24, 2013
jhill15's Avatar
Re: wheel help
New tires problem solved...on to the next issue
siliconvalley
Sep 15, 2015 09:48 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
rainman15
Sep 6, 2015 11:10 AM
