Ingalls Front Camber Question
Old Oct 2, 2011
bayamonboy1986's Avatar
bayamonboy1986 is an unknown quantity at this point
Trying to find out which Camber kit i need. I have my car dropped on Tanabe DF210 Springs. Cant find anything on whether I need the 14mm or 16mm bolts, or both.
Old Oct 2, 2011
sl33pyriceboi's Avatar
Re: Ingalls Front Camber Question
if u have a 2001-2002 civic, you use the 14mm bolt.
if u have a 2003-2005 civic, you use the 16mm bolt.
simple =]
this also depends on strut as well (because some aftermarket struts/coilovers use a 16mm with reducing washers for 01-02 application)
so what kinda struts are u putting these camber bolts on?
Old Oct 2, 2011
Stock struts
Matteo
Oct 25, 2015 05:46 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
