alignment problems
Old Dec 13, 2009
alex.w *//'s Avatar
alex.w *// will become famous soon enough
alignment problems
whats the reason for my car to lose its alignment?
the car does not wander and goes straight.
its just the steering wheel is off center
i've gotten a aignment 3 months ago and it was perfect.
been driving it everyday and nobody else touched my car, now my steering wheel is off centered again
Old Dec 14, 2009
CoupedUp04's Avatar
CoupedUp04 is an unknown quantity at this point
Re: alignment problems
check the tire pressure? did you rotate the tires after the alignment? i'm definitely no expert on suspension but 3 months might give it enough time to get off center again depending on the age of your parts...
Old Dec 14, 2009
are you driving on alot of bumpy, snowy roads? that can really throw things off with the suspension.
Old Dec 14, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Tire pressure as Couped said. Check tire wear on all sides and make sure that front L/R are even and rear L/R are even. Are your tires new or used? Because my car is doing the same thing. I took it in for an alignment, and there was no change. This is the same person who aligned my stuff when I got new tires years ago, and when he did it that time the alignment was perfect and stayed perfect for years. It just proves that the alignment isn't the problem on mine. Could be dragging brakes as well, shrug.
Old Dec 14, 2009
alex.w *//'s Avatar
can it be tie rod ends going?
tire pressure is same at 35psi all 4 corners
Old Dec 14, 2009
tie rod ends, you would hear nasty clunking sound when turning, like something is about to fall apart (which is possible actually lol, almost happened to me).
Old Dec 15, 2009
Justinsn95's Avatar
Justinsn95 is an unknown quantity at this point
I had a car once (mustang, not a honda) that kept getting out of alignment fast because of a bad ball joint. Replaced the ball joint, problem stopped. Might be worth a look...
Old Dec 15, 2009
batman900's Avatar
batman900 will become famous soon enough
I have the same problem on mine, not matter how many times I do an alignment the car still pulls to the right. After getting new tires and no change ive given up.
Old Dec 15, 2009
Justinsn95's Avatar
But yeah like the other member said, do you live down a dirt road, or drive over a lot of bumps all the time? That shortens the lifespan of an allignment, and it will need to be redone sooner.
Old Dec 15, 2009
batman900's Avatar
I can drive away from the alignment shop with a sheet of paper saying everything is in the green and it still pulls. I even took it back to 1 shop 3 times and they couldnt figure it out.
Old Dec 15, 2009
that means its a hardware issue. are your compliance LCA bushings torn?
Old Dec 15, 2009
batman900's Avatar
I dunno bout the other guy but I have new ES bushings and new tires. Comming soon is shocks and springs so if that doesnt do it ..... I dunno. My shifter and alignment are the only 2 things I absolutly hate about this car.
Old Dec 15, 2009
alex.w *//'s Avatar
it had the problem when my car was on stock springs and suspension. so i lowered it with eibach pro kit, and with stock shocks 3 months ago.
the car doesn't pull, it goes straight,
theres no popping sounds or binding sounds. everything seems normal.
just the steering is off centered.
i can adjust the tie rod length from the left side and taht will make the steering back to normal, but after couple of months, it will go out again.
civicowner123
Jul 24, 2015 10:02 PM
honda200192
May 31, 2015 05:57 PM
bo_red
Apr 23, 2015 10:09 PM
dret
Canada West
Jan 8, 2002 03:05 PM
RickyRocket
Nov 30, 2001 10:14 AM
