Good suspension for my 4 door??
hey everyone, im looking to change my suspension on my 05 lx sedan. im not looking for anything crazy. i dont want the top of the line sport suspension just something better than my stock suspension. i just cant stand how my car reacts on a turn. im looking for something affordable. something that will make me feel safer while turning lol. any suggestions would be greatly appreciated. thank you
Re: Good suspension for my 4 door??
It really depends on what you want in a suspension set up. Do you want it adjustable? (As in being able to lower it and make it higher whenever you please?) If you do then most people would suggest for you to get a coilover setup. If you want a stiffer ride and a decent drop most people will suggest a spring strut combo. It really all depends on how low you wanna go and how stiff you want your ride to be.
i want something stiff and something a little bit lower than stock. but like the other day a friend of mine was driving my car in a lot and just kept going in a circle and you can see how shitty the suspension is. it almost looks as though the car is about to flip over lol
Autocross Junky
bumpin4door, a couple of things you can do for little $$ to make the car turn better.
1. Optimize the cars alignment. aka, NON-OEM alignment
2. buy better tires (more grippe)
3. Install good aftermarket dampers (shocks)
4. install an RSX's rear anti-roll bar (either the 19 or 21mm one will be fine for your needs)
I have the Eibach Pro-kit sportsprings with KYB struts/shocks. It lowers the car 1" while still keeping a comfy ride for commuting. Then I'd suggest a better front sway-bar, the DC5 rear sway-bar, and maybe front, and even rear, strut tower braces. You definitely want to make sure you have good tires, or the rest of the suspension work will be meaningless!
I originally had the neuspeed racing springs that lowered the car 2.25", and it cost me a front lip and scars on my exhaust from all the damn speed bumps and steep driveways we have have here in Portland.
I'd go with some decent tires and maybe keep the stock suspension but pop some ES polyurethane bushings to help your cornering... You won't get your drop but you will definitely see a huge improvement. Search google for the top rated handling tires, and the bushings are all over the place.
http://www.skunk2.com/suspension_tuning.php
everything you want is right here. i'd suggest lowering springs. strut bars. and definitely front and rear kit camber kits. as for the tires thing, what kind of tires do you have?
i have almost every suspension upgrade possible, including front/rear upgrade sway endlinks and ES bushings, ES motor mount and lca bushings, strut bars, sway bars, lowering springs and upgrade shocks, none of it counts for anything with the cheapo tires i have now. the car handles like its stock.
tires do have alot to do with it. Also, from my personal experience: the camber has even more to do with it. depending on how your toe is adjusted, your car can handle turns much more aggressively even with stock tires.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
