bump steer ??????????????????????
Old Mar 9, 2009
lowlife9's Avatar
Exclamation bump steer ??????????????????????
Will there be any adverse effects from inverting my tie rods to counteract bump sreer for a 3 1/2 inch drop can you purchase reliable tie rods specifically designed for this purpose ?????????????
Old Mar 20, 2009
djmota's Avatar
Re: bump steer ??????????????????????
go to clubrsx and look into 0857 rteering rack bracket. its a bolt on mod that will help straighten out your tie rod angles and help with the bump steer problem. Fits the rsx and the 7th gen civic.
Old Mar 20, 2009
lowlife9's Avatar
cool thanks i really appreciate your info i will research this.
Old Mar 20, 2009
kcari's Avatar
whats the point of straightening them out?
Old Mar 20, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
do to the way the chassis is set up you can't run inverted tie rod ends on a 7thgen civic like you can with the rsx and si. cause when the suspension fully unloads it will slam the tie rod into the frame bending it or snapping it not so pretty. frame support is higher in our cars.
Old Mar 21, 2009
lowlife9's Avatar
i have seen kits for 2004 civics.here is one for 01-05 civic and 02-06 base model rsx.
Old Mar 21, 2009
Alpha 5's Avatar
This is interesting..... hhhhmmmmm
Old Mar 21, 2009
bomerman19's Avatar
I tried to invert mine but the frame got in the way and I could just disaster as soon as I lifted one of the front wheels off the ground. I have to much travel for it to work in my suspension
Old Mar 21, 2009
is your car that low causing the tie rods to be angled? how much did you drop it?
Old Mar 21, 2009
lowlife9's Avatar
im not droped yet my progress comps are in the mail im not sure if im going to go as low as i planed so the tie rods were an option but im thinking 3 inches .
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
