View Poll Results: Which Struts/Shocks??
Tokico Blues
24
48.00%
Tokico DSPEC
10.00%
Bilstein
10.00%
KYB
12.00%
Koni Yellow
20.00%
Voters: 50. You may not vote on this poll
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
Old Oct 19, 2008
  #31
D17alltheway's Avatar
D17alltheway will become famous soon enough
Re: *updated* Springs Ordered: Which Shocks/Struts *poll up*.
bought Tein SS's used for 300... sent em out to Tein to get em rebuilt for 395... so all in all spent 695 for a 1500 dollar suspension.. and it works like new
Old Oct 19, 2008
  #32
but as far as suspension goes.. people are always complaining about what coilovers blowout.. bs.. all coilovers blowout depending on how low you get and the conditions there driven in
Old May 15, 2009
  #33
Hunt4Steve's Avatar
Hunt4Steve is an unknown quantity at this point
Originally Posted by pheaton
.....I don't want much of a drop an inch or so is fine by me. The streets around here will eat my car if I do any more than that. Like I said I just want to be able to take the occassional corner a little rougher, or interstate on/off ramp faster without getting that out of control oh crap my car is going to hit the ditch feeling. I guess my main concern is ride quality, I want the ride to be smoooooth. I'm not trying to slam the thing, or hit up the track. Just a nice smooth ride with some improved corning ability.
Pheaton, I know this is an older thread, but your past issue is exactly the same position I'm in now.
I have an 03 Civic HX 5spd that I commute 80 miles a day in. Of the 80 miles, 20% is city and 80% is highway. With 126k on the ticker, I've recently changed the timing belt myself and the do all my own maintenance.
I recently got a new set of 195/60R15 Kumho Solus KR21 tires for my Civic, which I must say, are excellent tires for the commuter. After the tires were installed, I had the alignment done. I noticed the passenger side rear tire camber was negative a bit and pointed this out to the alignment shop. They brought it all into spec, but noted that the passenger side rear coil had collapsed a bit, and stated that these Civic coupes coils tend to get tired after 100k miles are put on them.
SO......since I commute in this car, I'm looking for a smooth ride, but I'd like to drop it 1" exactly for a better look and ensure that my camber is correct so my tires will last.
From what I've researched (Thank you Robbclark1 for the excellent FAQ suspension info, I know I need a camber kit), I'm going to need a few parts to do this correctly:
SPC Rear Camber Kit
Since the rear camber is non-adjustable from the factory:
http://truehonda.com/inventory.php?a...ctdetail&id=46
Shocks (struts)
I've read that the Tokico HP shocks will allow up to a 1" drop and be fine:
Front: HB4020, HB4021
Rear: HU3741, HU3741
Coils
Eibach ProKit 1" lower coils
Autopartswarehouse.com has them for $249 for all 4 coils
Part Number: E274051140
MFR#: 4051140
EIBACH PRO KIT LOWERING COIL SPRING SET -- Lowers front and rear by 1 in.; Progressive design; Offers high performance handling in the form of quicker stopping, faster cornering and better mileage; Lowers your vehicle's center of gravity and reduces excessive fender-well clearance for that look of performance superiority; With Eibach's million mile warranty.
So, Pheaton. What did you end up going with, and are you happy with your setup?
Since I commute, I'm looking for a smooth ride that is 1" lower than my stock setup.
Does anybody have any other information related to this kind of setup? I understand that most folks on this board are interested in slamming their Civic and will endure the harsh ride for cornering performance.
I'd like a 1" drop with a nice smooth ride......is this possible?
Old May 15, 2009
  #34
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Gearbox has the same springs and shocks on his sedan, I would PM him.
Old May 15, 2009
  #35
Hunt4Steve's Avatar
Thanks, sent him a PM.
With a limited budget (finally got the wife's understanding), I'm trying to do the right thing just once.
I almost ordered OEM replacement stuff, but then started looking around this site for what others have done when trying to retain a simple ride and slightly better looks.
Old May 15, 2009
  #36
i have eibach prokit and tokico HP blue shocks and spc camber kit. its exactly 1 inch drop all around. perfect for normal driving without worrying about scraping or bottoming out. and in the summer the ride is firm but still very smooth. in the winter its a bit rougher cause everything is cold.
Old Oct 12, 2009
  #37
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Sounds like I am in the same boat at Pheaton as well...
I was looking at ways to make the car handle a little better.
I've pretty much ruled out lowering it due to the average snowfall of 70 inches per year in my hometown of Grand Rapids...
It's looking like sway bars might be the way to go
Old Nov 2, 2009
  #38
Mavrick272's Avatar
Confirmed that every 6th gen model except the Si and EX did NOT come with rear sways, did come with front sways (at least the LX, I know for sure)
The rear lower control arms on the Civic LX and EX are the same (checked part numbers at MajesticHonda)
Apparently endlinks are interchangeable for 94-01 Tegs and 92-00 Civics
Since I have the disc setup from an 01 Teg, could I use a factory 01 Teg rear sway bar, or would I have to use one from a Civic EX?
I guess I'm asking which would bolt to the subframe (I plan on getting the ASR brace) properly? or would they both bolt up right?
the link on Honda's sway bar specs on RobClark's sig is broken
Old Nov 6, 2009
  #39
Mavrick272's Avatar
To anyone in the same boat (or as big of a n00b as I am) this really helped with sway bars:
http://www.jdmuniverse.com/forums/ho...formation.html
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
