Will Si springs fit?
Old Jan 25, 2008
Alex857's Avatar
Alex857 has a spectacular aura aboutAlex857 has a spectacular aura aboutAlex857 has a spectacular aura about
Hey everyone my buddy just took his goldlines off his si and i was just wondering if they will fit my 04 em2. he said he'll sell em to me cheap if theyll fit. Thanks everyone rep will b given.
Old Jan 25, 2008
SilverCivic504's Avatar
SilverCivic504 is an unknown quantity at this point
Re: Will Si springs fit?
they sure will
Old Jan 25, 2008
haha jk i doubt it
Old Jan 25, 2008
popee's Avatar
popee will become famous soon enough
they dont fit..
Old Jan 26, 2008
Alex857's Avatar
shiiit lol. I think its like an 00 or 01 si. Damn lol
Old Jan 26, 2008
dude goldline sucks. i think they give em for free when you buy rim combos from wheelmax or something. you can buy used eibach sportlines for like $100
Old Jan 26, 2008
Alex857's Avatar
yeah but for 25 bucks you can't beat it lol.
Old Jan 26, 2008
popee's Avatar
lol better off paying a lil more for a more comfortable ride
Old Jan 26, 2008
robbclark1's Avatar
Retired suspension supermod.
This is why we have a FAQ, please read it.
https://www.civicforums.com/forums/4...ease-read.html
Will DC5/EP3 suspension fit my EM2/ES1 and vice versa
Yes, but it will require modification.
If you can find early EP3 stuff, then it should be a direct swap. Later years, Honda switched to 16mm strut bolts and larger tie rod ends.
To make a long story short this is what you will need to make things fit.
1) If you have a full coilover system with a front upper mount/camber plate, then all you will need is DC5/EP3 tie rod ends. You may or may not have trouble with the rear strut bolt. Sometimes they are bigger, sometimes they aren't.
2) If you have a full coilover system without a front upper mount/camber plate, then you will need DC5/EP3 tie rod ends and you need your upper mount from your stock suspension. It is not suggested that you use DC5/EP3 upper mounts.
3) Progressive springs (ie NOT coilover springs) WILL NOT FIT!! Technically they will fit, but the springs are designed for specific weight distributions.
4) Shocks from DC5/EP3 will fit if you keep your upper mounts and get new tie rod ends.
5) If you have a 2001-2002 EM2/ES1, then you probably will need to drill out your strut mount holes to 16mm. This is not an easy job and not recommended. It also is not recommended that you use your 14mm bolts on the 16mm holes because you run the risk of camber sliding.
6) Other misc DC5/EP3 parts may or may not fit. SOME strut bars fit, ALL rear sway bars fit, SOME front sway bars fit, ALL rear tie bars fit.
Old Jan 26, 2008
speedfoos's Avatar
honda.lioness
16
Feb 10, 2017 10:53 PM
cukaracha
Aug 29, 2015 05:27 PM
Curtchuk
Aug 5, 2015 02:14 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
