Why Do I Scrape Alot In The Rear?
Old Jan 1, 2008
IrockCivics's Avatar
I dont know why but when I drive alot and theres like a little hill or a driveway I seen to bottom out but only in the rear so I decided to look under my car and I figure out where my car was touching at so I took a pic.... My question is why when I put 2 people in the back seat my car get so low I can have anyone in the backseat cause of my car rubbing... I circle the spot in red when my car scrapes maybe you guys can help me out I have H&R's sprins with Koni Yellows.
Old Jan 1, 2008
speedfoos's Avatar
Re: Why Do I Scrape Alot In The Rear?
How long have you had the Koni's on there? Sounds to me like they are blown, or you need to step up to some stiffer springs. How low does she hunker over the back tires?
Either that or you just need to get some thinner friends.
Old Jan 1, 2008
robbclark1's Avatar
Retired suspension supermod.
Because you are on neuspeed race PROGRESSIVE springs. When you put weight in the rear, the springs are going to compress more. Progressive springs do that more than linear springs. Your car is low to begin with, so putting weight in the rear is going to make you scrape.
Two relatively cheap fixes
1) Get a new set of springs with a lower drop
2) Get a set of GCs for konis.
Old Jan 1, 2008
The konis are there like about 1yr and 3months... I use to have neuspeed on the rear with the konis but it was sagging alot plus I had my system in there, so I changed to H&R's to see if the rear would get a little higher it did like for 2weeks and then again it went low, The h&r's were use by the way...
I had my si's on with 195 55 15 and the rear use to cover the tire you can only see the rims... But like 3weeks ago they try to steal my si's so I put on 91 integra steelies so know it bottoms out alot, thats one of the reason I dont drive my car.. The front is still on neuspeed race springs but with tokicos but I never hit in the front.... I was thinking of buying some teins super sport and getting new tokico shocks but I wanna be sure that this will be good for my car or not I just gonna get the oem springs on ***** a hastle.
I want to get new springs and new shocks but I dont know which to get, I really dont know nothing about that and all my friends around here are into the luxury cars so they dont know either lol... I also notice like a knocking noise when I turn the steering wheel to the left or right.
Old Jan 1, 2008
ronaldo9's Avatar
Knocking noises sounds like you need new bearings on the top mounts. KYB make replacements that I will be buying soon.
Old Jan 1, 2008
speedfoos's Avatar
^^^^ Yeah. I was gonna buy some of those too until dopes067whatever dropped his prices and and I'm buying the Wisecos now instead.
Old Jan 2, 2008
robbclark1's Avatar
If on a budget
Eibach Sportlines
Tokico blues
F/R camber kit
If you want adjustability
GCs
Konis
F/R camber kit
Old Jan 2, 2008
Since I will be buying new springs will the knocking noise still be there?
If on a budget
Eibach Sportlines
Tokico blues
F/R camber kit
GCs
Konis
F/R camber kit
I might just get the
Eibach Sportlines
Tokico blues
F/R camber kit
Thanks for the info.
Old Jan 2, 2008
ronaldo9's Avatar
Yes, the knocking will still be there it has nothing to do with the springs. My problem came bc I had a blown OEM strut and the oil leaked into the top mount and it caused the bearings to move around. When we opened it up there were bearings on top of bearings which is not good.
Old Jan 2, 2008
Ok so if I replace the shocks, will it go away?
Old Jan 2, 2008
ronaldo9's Avatar
I honestly dont' think the shocks are the problem its the top mounts and those are cheap compared to replacing shocks.
Old Jan 3, 2008
what are top mounts? Sorry I know Im a idiot lol
Old Jan 3, 2008
ronaldo9's Avatar
This is what you need. This is what goes on top of your shocks and springs. The bolts that stick up are what your strut bars mount to. Hope this helps.
http://www.prostreetonline.com/oem/q...tion=000748425
Old Jan 3, 2008
robbclark1's Avatar
Why would front top mounts help the rear from scraping?
He needs springs with not so low of a drop.
Irock, what are your suspension mods? It says that you have tokico blues, but the picture shows konis.
Old Jan 3, 2008
ronaldo9's Avatar
Rob I was responding to his comment on the clicking noise when he's turning in regards to his front shocks not the rears. I thought it was a given his drop is too low in the back.
Old Jan 3, 2008
Buds302's Avatar
Buds302 will become famous soon enough
how much stereo equipment is in the trunk? im sure its not helping the situation
Old Jan 3, 2008
ronaldo9's Avatar
You have koni rears correct. Are they on the top or bottom perch. If they are on the bottom and you move them to the top perch you may raise the back a bit.
Old Jan 3, 2008
nineteenem2's Avatar
nineteenem2 is an unknown quantity at this point
No Fat Chicks Car Will Scrape!!!!
Old Jan 11, 2008
SevenKRedline's Avatar
SevenKRedline is an unknown quantity at this point
Or dudes, if you're into that sort of thing......
Old Jan 13, 2008
lemac's Avatar
lemac will become famous soon enough
Buy a set of Tien coil overs... I've seen a set of basics go for like 900.00 they come with springs and adjustable spring perch so you can lower or raise to your liking. Are you sure the knocking isn't from the axles going out? Try turning the wheel while not moving and the same while the car is moving. Let us know when it knocks moving or not moving the car that is....
redcloud
Sep 7, 2015 01:45 PM
Shadow277
Aug 31, 2015 12:30 PM
naokigoffi
Aug 30, 2015 06:19 PM
MamaBear2015
Aug 25, 2015 10:47 AM
jordan1794
Aug 13, 2015 10:20 PM
