Tokico HP Blue w/ Neuspeed Race springs or Skunk2 coilovers
I have a 2002 civic ex, I really dont want too spend too much on coilovers so I decided to go with Tokico HP Blues and either Neuspeed Race Springs or Skunk2 coilovers.
How is either of this setup?
Pwning Noobs 24/7
Re: Tokico HP Blue w/ Neuspeed Race springs or Skunk2 coilovers
the tokico's will blow, tokico's can only handle at max a 2 inch drop, great for Neuspeed Sports, with the Skunk 2's (2-3 in drop)or Neuspeed Race (2.5 in drop ), Koni Yellow's are you best bet
You Stay Classy, San Diego
so wut if i put the skunk2 on some hp blues but didnt put them as low as they can go am i still screwed? Wut about ground controls?
Skunk2 coilovers DO NOT FIT OEM struts!! I found this out while trying to install the coilovers. Also, beware of the fact that you will most likley need a camber kit as well once you lower your car (unless you can care less about your tires). I dont know how the tokicos are built but i will say that im not sure if the skunks will fit.
Hi, i just bought Tokico HP Blue shocks/struts for my civic. I have a 1.5 drop already so i don't think the shocks should blow correct? or and i wrong?
You'll be fine with a 1.5" drop on blues. My first suspension setup was a 1.3/1.4 F/R drop (Tein S-Tech) on blues.
How low do you wanna go ? Eibach pro kits can handle up to 1'' drop, or else you can try Eibach sportlines, I would say max 1.5'' on tokico blues.
Shocks can blow, depending on the usuage. If you want to slamm down, It would be better to go for konis .
i drive
Sep 14, 2015 01:56 PM
RedDragon333
Oct 19, 2002 12:08 PM
sKwiD
Aug 12, 2002 12:43 PM
