Cut Bump Stops?
Old Feb 6, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Cut Bump Stops?
I just installed Tokico Blues and Tein S-techs last week. I didnt cut the bump stops and i think i will now (unless i dont need to let me know!) but i cant find the instructions! Just need to kno how much im supposed to cut the bump stops for the s-techs??
thanks
Old Feb 8, 2007
metalviper's Avatar
bump
Old Feb 8, 2007
ronaldo9's Avatar
You do not need to cut ur bump stops period. Unless you want to be slammed but then why would you buy s techs. So leave them as is.
Old Feb 8, 2007
metalviper's Avatar
but bump stops dont effect the ride height! just the rebound of the shocks
Old Feb 8, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
the bump stops dont effect the ride height, but they also dont do anything for the shock rebound. It stops the upper mount from slamming into the top of the shock. Its a failsafe that gently stops the travel once you run out of it.
The only thing cutting bumpstops or shortening them would do for you is buy you an extra inch or so of travel. So while they dont effect the ride height, the ride height is the reason that would necessitate the cutting. The lower you go the less travel you have so being able to buy some more is often advantageous.
I dont think S-techs would drop a car far enough that you'll need to cut them, there should be ample travel with those springs.
Old Feb 8, 2007
metalviper's Avatar
alright...so then i really dont need to. i guess it would be a lot of trouble to take apart the strut to cut the stop if its unnecessary.
Old Feb 9, 2007
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
in simple terms then protect from the shock hitting the uppermounts if then compress all the way. and like boiler said cutting them makes room for more travel. at the same time it's less cushioning if they "bottom out". but for s-techs...... thats far from slamming so it dont matter. you probably dont even need to run bump stops for the stechs...... but please, do run them.
Fudman
Suspension
Feb 1, 2020 04:13 PM
MN-02-CivicEx
Jun 25, 2015 08:32 PM
rayman7
Jun 20, 2015 09:48 PM
1028CiViC
Mar 21, 2002 11:29 AM
SugarRay
Jan 28, 2002 05:17 PM
