the "popping noises" sticky
Old Oct 22, 2006
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
i dont have popping noises, so dont close this yet......
the problem i have i think is with the bearings in the upper mount for the spring that lets the strut turn. every time i drive over a pothole or something that makes the spring/strut extend and then compress again theres a sorta loud clunk that happens.
it doesnt happen on bumps that only make the suspension compress though.. which is why im confused about it
this was referenced in the sticky but it wasnt too specific.............
i read a thread a while back about how the 2001s have a plastic ring up on the mount insead of a metal bearing and that it wears down and thats why its happening but i dunno if that true or not
so gimmie some input people, do i need to buy new mounts? new bearings?thanks
Old Oct 22, 2006
ragingSPAM's Avatar
I just burnt my tongue
new upper mounts...the 03-05 have a bering design which i think is more efficient(i've worked on many civics so its from experience)
Old Oct 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
check the struts themselves. Bumps and loud clunks usually = blown struts
Old Oct 22, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
I have exact same problem!! first i thought it was my blown shocks.. but it was the rsx sway bar. so if i were you, tightened all the endlinks bolts and screw and check if the noise goes away.
Old Oct 22, 2006
01vic's Avatar
thats exactly what i thought too untill i replaced them with tokicos and the sound was still there.... (and yes they are indexed right, i was pretty careful)
ohsnapsjay08
i wish i had a rear sway to make noises, but i dont (dx).... and its definately coming from the front
hey ragingSPAM, do the 03 -05 upper mounts fit the 01? if so i will order them and see if thats the issue b/c i cant think of anything else it could be...
Old Oct 23, 2006
NOTORIOUZ's Avatar
NOTORIOUZ is an unknown quantity at this point
ha i had the same issue, the day the shop installed my shocks and springs the noise started to happen. So its not usually blown struts.check if u have "Coil Wrap" around the bottom of your springs. That was the issue for me.
Old Oct 25, 2006
01vic's Avatar
is it possible that its the fraont sway bar being loose??? b/c i just found one of my sway bar links is all worn out and i need new ones, so maybe ill go under there and tighten all that up..
Old Oct 25, 2006
LilJohn198807's Avatar
LilJohn198807 is an unknown quantity at this point
I have kinda the same problem ......Mine is lowered 3" on drop springs with HFP struts and I get pop when I turn .....is that cuase the bottom of the spring or what?
Old Oct 25, 2006
CenZ's Avatar
PWIT
thats prolly your spring not being indexed correctly.
Old Oct 25, 2006
Wngman200's Avatar
Wngman200 is an unknown quantity at this point
I think he's right. I had b&g 1.5 inch drop springs and they didn't have any wrapping on the bottom of the spring, but when I got my skunk2's (which had the coil wrap on em) the noise stopped. Try that....
Old Oct 25, 2006
Synapz's Avatar
Synapz is an unknown quantity at this point
my buddy club racing specs on my em2 make a lot of popping noises =\
Old Oct 26, 2006
01vic's Avatar
i dont have a drop people... so its not my drop... i am going to get spring wrap and new front sway links and see if that works
Old Oct 27, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
I've recently been getting the same noise too... I think it might be my upper strut mounts... can anyone confirm if the 03-05 upper strut mounts fit an 01-02?
Old Oct 27, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
yes they fit
Old Oct 29, 2006
knight_321's Avatar
knight_321 has a spectacular aura aboutknight_321 has a spectacular aura about
i just installed my coils 3 days ago and i get this weired clunking sound now and then, is this just the spring s settleing in or is their a problem and should get it checked
Old Oct 29, 2006
gagne123's Avatar
gagne123 is an unknown quantity at this point
I have the same problem, I just installed the Tokico blues with the matching one inch drop springs, when i turn my wheel back and forth the front right spring will "pop". I went to get an alignment, and they told me i must not have installed the mount properly because when the car is jacked up you can litterally spin the spring back and forth. when I take a right turn and then go straight my car "memorizes the turn" and wonders right after going strait. and when I take a left turn and start going strait my car pulls to the left. I thought i indexed them and put it all together right. so either my mount is jacked up and i need a new one or i screwed up.
Old Oct 29, 2006
Nameless's Avatar
TURTLEonK
^ just reinstall... sounds like its not indexed properly
Old Oct 29, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
im not sure if its confirmed that its the struts yet, but you mgiht also want to check your tie rod ends for play, that will often cause a "popping" sound while turning.
Old Oct 30, 2006
knight_321's Avatar
i have the clunking sound but its not very noticeable, it only happens now and then, all the alighnment and is fine and my car doesnt drift left or right when driving straight.
is the light clunking sounds just the springs settleing in or is their a problem?
Old Oct 30, 2006
Nameless's Avatar
TURTLEonK
what type of springs are u using? and for how long (miles) have u had them in?
also what year is ur car with how many miles?
Old Oct 30, 2006
gizcivic's Avatar
gizcivic is an unknown quantity at this point
I had the same issue 2yrs ago. I found out it was the front sway bar. It was loose after I tighten it the noise went away
Old Oct 30, 2006
01vic's Avatar
werd up
i think that is what my problem is i just have to find some time to get under there and tighten it up
Old Oct 30, 2006
knight_321's Avatar
My car is 05 ex, BC coils put in less than a week ago
Old Oct 30, 2006
jaydm21's Avatar
jaydm21 is an unknown quantity at this point
i have a popping noise whenever i turn left or right, im lowered on H&R springs and for the first few months they popped but i figured it was just the springs settling in because i knew they take time to fully settle but it's been over a year now and they still pop every now and then and especially in cold weather. i guess they were just never indexed right. i've also been told that with springs, they're always gonna pop is that true or is it just b.s.?
Old Oct 30, 2006
chugster's Avatar
1337
chugster is an unknown quantity at this point
Yea for some reason my tein flex does the samething. Whenever I turn right or left it makes a loud popping, clunking noise and I dunno why it does that.
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Whitexj
Sep 30, 2015 02:04 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
JJ291
Sep 2, 2015 11:49 PM
