New Tokico D-Spac member
Subscribe
Aug 1, 2006
i just got my d-**** installed......
but at softer setting if makes squeezing noise from front driver side
i told the guy to put enough Gris so this dont happens but it still does, any 1 have this setup and problem or any idea???
Reply 0
Aug 1, 2006
spec
Reply 0
Aug 1, 2006
d *****? is that the new version of the d specs???
Reply 0
Aug 1, 2006
sorry for the typo but no answer yet...
Reply 0
Aug 2, 2006
That is the reason I do'nt let others work on my cars. I would suggest to pull the wheel off and make sure that everything is installed correctly. Do you have stock springs or aftermarket?
Reply 0
Aug 2, 2006
ive had them for about a year and never had a problem, how soft of a setting do you have them at. Im set at least three all the way around.
Reply 0
Aug 2, 2006
Quote: d *****? is that the new version of the d specs???
Reply 0
Aug 2, 2006
Quote: That is the reason I do'nt let others work on my cars. I would suggest to pull the wheel off and make sure that everything is installed correctly. Do you have stock springs or aftermarket?
i have tokico springs that came with the kit
Quote: ive had them for about a year and never had a problem, how soft of a setting do you have them at. Im set at least three all the way around.
5 turns front and 3 turns rear
Reply 0
Aug 2, 2006
Like I said, just make sure everything is installed and tight. Add a light film of silicone grease to some moveable parts.
Reply 0
Subscribe
