Fckig GC coils
Fckig GC coils
ok, I probly have the wrong set or whatever but I can't figure this sht out, my drives sides suspensions are all off and I'm at a stand still.
I've searched with no luck, can somebody help me out, how do these things fit on an 01 coupe ex? riding on stock struts
model #s
112640
gc150.64.66
and
86544
gc125.64.75
and if somebody sends me the diy on spring install,
, I don't even want to talk about it
any help, thanks!
model #s
112640
gc150.64.66
and
86544
gc125.64.75
, I don't even want to talk about itany help, thanks!
I need TP for my bunghole
Go to the source: http://www.ground-control-store.com/...gory.php/CA=55
Gere is a pic from the source:
just putting the whole assembly on the strut, it doesn't fit, so I guess IDK
well here is the deal, the sleve wont fit over the strut, stock struts, and even if they do the support for the spring is huge, I have 4 rubber O rings I have no idea to do with what, ugh
now I'm stairing at this screen with my car apart outside....
Last edited by thefivespeeder; Jul 21, 2006 at 04:50 PM. Reason: Automerged Doublepost
haha, listen i appreciate the concern, but I've been a mechanic for 5 years, but I've never done sleeved coilovers, I've just heard people having problems because of the various versions for years and have a stock setup, the kid had an 2001 lx sedan, i have a 2001 ex coupe, but it's all the same for 01's no?
OK. provided you have the right stuff it really isn't that difficult.( they also should have come with instructions). #1 fronts...you don't have to cut the front spring perch if you don't want to. It just cleans up the install a bit and allows you to slam your car to the lowest setting. on the front you have to pop off the strut cap before you attemp to slide the sleeve on. before you slide the sleeve on, slide on one of the o rings around the body of the frnt strut. then slide the sleeve. and pop back on the cap. slide the spring on then the aluminum spring hat. then bolt the top hat to the strut.
the rears use a rubber sleeve instead of the o ring and they also use a rubber spring hat instead of aluninum. make your left and right setting the same and adjust from there never losing count of how many turns you did on one side.
when i did mine it was gc's first version back in the day yours should be the same hope this helps
alright thanks for your concern and help again guys, yea i tried pulling that cap off the top of the strut but i was afraid to mess it up so i stopped, i think you just cleared it up, yea the kid didn't include instructions, also where to these caps go on the front right? well thanks again. +rep
just the top washer looking thing or the whole cap?
anyone?
anyone?
Last edited by thefivespeeder; Jul 21, 2006 at 06:24 PM. Reason: Automerged Doublepost
um, how do you do that...? lol I never had to take a shock apart before?
oh and the gold caps goes on the fronts right?
geez I never thought sleeved coils would be this fcking hard, should have just stuck with springs...
anyone wanna throw me a life line? wish this just came with directions...
ok thanks 'djmota' i've got to write a excerp in the spring install, for sleeved coilovers, jeez
Last edited by thefivespeeder; Jul 22, 2006 at 10:42 PM. Reason: Automerged Doublepost
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
