ok guys, me and my friend were gonna install new shocks and springs, so we unscrewed the 2 bolts that held the shock and the rotor/axel together, i dont remember letting the rotor fall to its lowest, we gently let it down as far as the thing would go, then we decided to just **** it and take it to a shop. and now the damn rotor/axel wont push up 10 degrees to fit into place w/ the shock so that i can put the 2 bolts back in. i tried shaking the rotor and messing w/ it so i would push up but no luck. any ideas!?!?
Finish the installation yourself? or pay to have the mechanic come to your house and do the job?
Sucks learnin the hard way
ok ur not getting what im saying. i just want to know whats wrong w/ it, IN ORDER to finish the job myself
Have U tried using a hydrolic jack to push it back up. and I U do decide to do it do it very gentley.
Gently with a hydraulic jack... Priceless.
But seriously, pics would be very very helpful.
I accidentally dropped my rotor before I could support it with a tire, I felt something pop apart inside the axle also. It will take a while, but if you move it around enough, you can get it back in. It took me probably 30 minutes to, but I eventually got it.
yea that happened to me while i was dropping my car, just wiggle it around for like 20 mins or so and it should go back into place....at least thats how long it took to do mine
Hey! Look At Me!! I'm a Supporting Member!! Yep wiggling aroubnd will fix your problem. it happened to about everyone i know lol
yea its normal to happen just be patient and work with it
