spring orientation
Old Jun 4, 2006
AlienX's Avatar
AlienX will become famous soon enough
spring orientation
do springs need to be installed in a specific fashion ? lettering upside down or right side up ? does it make a diff ?
just a little confused here, so if anyone can answer this with technical knowledge it would be greatly apreciated.
Old Jun 4, 2006
jaydm21's Avatar
jaydm21 is an unknown quantity at this point
i dunno what kind of springs you have but i got the h&r springs and they were labled where to what corner they went to. as far as installing them, on mine the bottom of the spring has 2 coils that are together and the upper has one coil by itself. the end with two coils goes in the bottom. if the springs have writing or the logo on it then it should face up where you can read it normal, thats how mine are. sorry if this doesn't make since but its the best i could think of on how to explain it. good luck with the install!
Old Jun 4, 2006
XxSoVeReiGNxX's Avatar
pretty sure that's how variable-rate springs (and coilovers) get installed. The tighter packed segment at the bottom, and the a looser/wider segment at the top.
When i installed my DropZone springs, the logo on the springs in the front were correct, but logos on the rear springs were upside down...
Old Jun 4, 2006
pon55's Avatar
O no, you put the rears in upsidedown.
Old Jun 4, 2006
RHCP0801's Avatar
my neuspeed sport rears went in with the lettering upside down, i dont know about fronts tho but if you want i can take pics of the front springs on tuesday when i put my new wheels on
Old Jun 4, 2006
AlienX's Avatar
ya, i got HRs and I installed them with the tighter coils at the bottem... but again, the way I see it. Does anyone have any tech info on why springs should be installed in such a fashion ?
Old Jun 4, 2006
basically the tighter coils are "softer" and will compress more easily than the wider spaced coils, because of the design.
the tighter coils are on the bottom compress to absorb minor bumps and imperfections in the roads, before passing the force to the wider coils and then into the body of the vehicle.
having the spaced out coils on the chassis allows the spring to react faster when there is a dip or recess in surface level. The vehicle's weight pushes against the wider coils and makes it expand before the tighter coils can expand.
The tighter coils at the bottom make the major movements during "Jounce". The wider coils at the top play the lead role in "Rebound".
hooray for physics! special thanks to RHCP0801 for letting me borrow the great shot of his suspension!
200 hours in MS Paint
Old Jun 5, 2006
AlienX's Avatar
damn, that musta took a while +1 for that
i get what your trying to say, but if the springs where installed upside down per say... wouldn't the tigher/softer coils still compress before the harder/more open ones ?
Old Jun 5, 2006
that i really havent caught the concept of yet either
I know that if installation was reversed and the tighter coils were at the top, whenever there's a bump in the road the entire spring would move up until the tighter coils at the top absorb the force. I guess all thats just waste motion and dont know if it has any bad effect on the strut/shock.
but it's pretty hard to install them upside down since the spring only fits good one way over spring seat of the strut (on our cars anyway)
Old Jun 5, 2006
RHCP0801's Avatar
glad my pic came in handy
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
