GC Coilover Question
Old Apr 27, 2006
P40vic's Avatar
P40vic is an unknown quantity at this point
I'm about to install my rear Koni Yellow/Koni sleeve coilovers and I'm wondering if you guys grease the threads on GC coilovers to make it easier to set ride height? I'm assuming you have to lift the car to adjust them, do you also need to compress the spring? I'm worried about galling the aluminum threads while adjusting them since the spring is preloaded.
Thanks
Chris
Old Apr 27, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
You have to lift the car to raise the car because unless you're really strong, you're going to fight the weight of the car to make adjustments. When you jack the car up, the spring leaves the seat, making the seat free from preload... you just have to deal with all the **** that gets caught in the threads preventing you from turning them. I wouldn't grease the threads because you'll make em a dirt magnet.
Old Apr 27, 2006
P40vic's Avatar
I'm with ya on the lift the car first part, but the springs won't unseat because they're only 375lb and will be preloaded some even with the shock extended. The preload makes it pretty hard to turn the seat; you'd still go without grease because of the dirt issue?
Thanks for your help BTW.
Chris
Old Apr 28, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Mybe just coat them with WD-40, it's not to heavy.
Old Apr 28, 2006
djmota's Avatar
don't lube them with anything its not needed what so ever. There is no preload at all the springs are short. just jack it up loosen the collar, spin, and tighten the collar. your done.
Old Apr 28, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
With my teins ss, just jack it up and I use your muscle power to turn wrenches.
Its not that hard...or may be I'm strong.
Old May 3, 2006
azn2k1civic's Avatar
azn2k1civic is an unknown quantity at this point
i never greased mines, and i adjusted them today. Dirt will be there regardless of grease or not, but with the grease...it'll just be gunky. They were pretty easy to adjust, but still had to put a little back into it. haha. But i say you don't have to grease the sleaves...
GolNat
Jan 12, 2021 09:06 PM
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
