Tie Bar Template
PC Tech / Autocrosser
Tie Bar Template
If anyone with a DX was interested in knowing where the factory mounting points were for the rear sway bar brackets, I took the time to take some measurements off a rear tie bar (i won't say who for copy right reasons i'm sure) but this should give you a rough idea with measurements. It would be easy to draw out on paper and then transfer to the subframe using a marker.
Or for anyone that could do metal working, this would be a great tool to use to make your own custom tie bar.
I don't know if this will be of value to anyone but I got bored and took a stab at trying to contribute something here. Hopefully the measurements are right. I haven't really tried it myself since my focus is on my project 240sx right now.
hopefully the image makes sense. Someone who can use autocad would probably be able to make another image easier to follow.
Raiool
Oct 1, 2015 10:42 AM
