K-Swappers w/ x brace?
I Hunt Goats, Rams, And Mustangs.
Im just curious if there is anyone who has done a k-swap and put an x brace on their car. Or will it even fit? Just curious.
Boost is so good make you wanna slap ya mamma
An x-brace should fit with a k swap. But if you have a bigger exhaust system it may not fit cause mine won't fit with my turbos downpipe and exhaust. It should be fine with a drop you just need to be careful about going over bumps and curbs. Where in Norcal are you?
Wow that sucks your like right in the middle 3 hours from Norcal and about 3 hours from Socal. Also I want to sell my x-brace cause it won't clear my down pipe if you want to buy it from me we could meet up so you can test fit it to make sure it will work.
what exactly does it do?
i was looking to get one.. but i just really dont know exaclty what it does.. its for handleing right?
Last edited by DUDEitsMATTx; Mar 19, 2006 at 11:21 PM. Reason: Automerged Doublepost
Yeah the x-brace hangs a little lower than the oil pan so if you bottomed out your car the x-brace would hit first.
Dixon (95620) About 3 hours away. If you are going to the april 15th meet we can do the sale/ test fit install there unless you wanna meet sooner thats fine.
im on tein stechs and i have the d3 designs double xbrace (6point) and i only have 2" cleaence from the road to the brace on the lowest point in the brace.. the highest point is 2 1/4inch i dont scrape on smooth bumps but i scrape on bumps that a uneven or just too high.. even i angle on some bumps i cant clear
right now im the only em2 with this brace and the first as i tested fitment for d3 designs on my em2. got it at a special price too =D
