rsx rear sway bushings
Ashho-san 7thgen Ninja
i already searched and coudlnt find what i was lookin for. what is the best set of bushings and endlinks to get for the rsx rear sway?
you can make your own endlinks.http://www.7thgencivic.com/forums/sh...=made+endlinks
Just get the stock bushings at an Acura dealership for comfort or you can go with the aftermarket ones but you give up comfort for performance. The stock ones are dirt cheap so buy both and see which you like more.
http://www.prostreetonline.com/buy/p...shings/8-1136/
other places sell them aswell
is there anything else needed to do this install, just rsx sway bar and bushings? i know some people have said endlinks will snap, if you drive your car to the limit or what have, but most seem to make there own or get hotchkins i believe
since you have the oem 19mm rear sway your endlinks shouldn't snap, but if you put the 22mm bar on there they will for sure. i went throu a few thats why i made those upgraded endlinks
The progress bar snaps endlinks because they messed it up and still haven't fixed it.
The 22mm OE bars (DC5R) and their direct mimics (Comptech) do not snap endlinks. The RSX uses the same endlinks with a 21mm bar STOCK, and I don't hear they rolling off the lot and breaking.
is this the kit i need for the OEM rear sway rsx
Universal Universal Greaseable 3/4" 19mm Sway Bar Bushing Set (Red), 64185
thats the energy set btw
Drunken Master-7thgen Ninja
dude, the civic endlinks are the same. i checked when i did my install. they are EXACTLY identical. if the rsx can use the 19mm with them, then my car should be ok too. and from what i learned on this site, the endlinks break when you install the sway bar upside down. just do it right
juror
Suspension DIY
Jul 30, 2019 03:28 AM
fordover
Jul 11, 2015 09:10 PM
