I Cant Find Them!
Old Feb 20, 2006
hurley2301's Avatar
hurley2301 is an unknown quantity at this point
I Cant Find Them!
any recommendations for a guy on a budget?
01 sedan
shocks and
2.5 to 3 in drop springs?
i dont know **** about the shocks.
and i just cant find 2.5 to 3 inch drop springs
Old Feb 20, 2006
SLO REX's Avatar
250+ awhp Stage 2
Progress settle to 3 inches.
Old Feb 20, 2006
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Well before this gets locked I'll try to help you out. First of all what is your budget? To my knowledge there is no lowering springs that will go that low. I think Neuspeed Race are the lowest (2.25 F 2.0 R). If you want to go that low you should look into either full coilovers or sleeved ones. If you decide not to go with full coilovers and go with sleeved you're probably going to have to go with Konis or D-Specs shocks for a drop that low.
-edit-
I guess i stand corrected on springs that go that low. I was going on manufactuers specs.
Old Feb 21, 2006
hurley2301's Avatar
well. i just want somethign low. that might eb to low. and for price. ill just say cheap. just gimme options.
Old Feb 21, 2006
Cheapest way
-Sleeved coilovers from ebay
-Keep stock shocks
-Have fun bouncing around
boilermaker is going to have a very nice reply to this thread haha
Old Feb 21, 2006
SLO REX's Avatar
250+ awhp Stage 2
^^^It might have something to do with USE THE SEARCH BUTTON.
But yeah, if you are looking for something low, just get Progress springs, they will run about $50 used. Hell I might sell you mine when I get them off sometime this month.
Old Feb 21, 2006
Civicman1988's Avatar
progress makes a good spring.
Old Feb 21, 2006
SLO REX's Avatar
250+ awhp Stage 2
No they don't. It says it is a 1.5 inch drop, and as you can clearly see, they are really about 3 inches. That is more than double the drop they say it is.
Old Feb 21, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Cheap ebay coilovers sleeves will get you 3" in low. Maybe more when they break.
Old Feb 22, 2006
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Go Neuspeed race, camber kit. If your going to use stock shocks, you will kill them in no time.
Old Feb 22, 2006
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Talking
If your going to use stock shocks that are pre-valved for OEM settings, a 2.5" to 3" lowered spring is not very safe first off. The main reason is that your spring rates at that short of a spring will be much higher. The spring is going to be woven tighter with larger coils in smaller amounts to hold up the weight. This in turn will give you an undesirable ride with the "bouncy" feeling since the shocks are not valved to handle that kind of weith transfer. For that low of a drop the Koni shocks are needed to work safley. Obviously, im very partial to correct suspension setup and many have gone the "drop it hard" and no shocks way and have ended up taking 2 steps. 1st. Buy springs and get install 2nd. Buy shocks, and redo install.
As Peter said, A camber kit will be necessary for correct driveability, handling, and tire wear.
Old Feb 22, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
Tein basic (or ss if u have the money) full coilover, 500+ used, SS run like 1200 new on ebay
Old Feb 22, 2006
Touge Whore's Avatar
K-DUB
Touge Whore is an unknown quantity at this point
Exactly! Do not waste time with a eBay setup. This will only lead to headaches and more money spent to buy the setup you should have originally bought in the first place to "slam" your ride. Tein Basic's will be enough ride height adjustment for you....but have fun with -1000 degree's of camber without corrective mounts/rear arms.......so overall you are looking between the range of $600-800, so your defintion of cheap may fall in that category....
Old Feb 22, 2006
truehonda's Avatar
To achieve a proper 3" drop:
Koni + Ground Control
Progress CS1 Coilovers
We have em both, but besides that, these setups are pre-valved and made to handle the kind of lowering you want.
Old Feb 23, 2006
SLO REX's Avatar
250+ awhp Stage 2
I have been running a 3 inch drop on stock struts for about 20,000 miles and nothing is wrong with them.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
jherna85
General 7th Gen
Jul 9, 2015 08:10 AM
trellex
Jun 30, 2015 07:13 PM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
