01 civic ball joint help.
Old Jan 16, 2006
civicrider01's Avatar
civicrider01 is an unknown quantity at this point
Ok, I need to replace my ball joints. I think its only my passenger one. From this site, which one should I get, how many (quantity) should i buy? is there a diy on replacing a ball joint? i searched, thanks.
http://oem.overnightautoparts.com/pa...0Joint&dp=true
Old Jan 16, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Go here for the pricing and diagrams: http://www.hondaautomotiveparts.com/...tcgry5=KNUCKLE
Reference 3, 4, 19 & 20 on the pic. You'll need one for each side.
Total for both sides $ 56.60
Old Jan 23, 2006
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Did you get the job done? mine also need replacing
Old Jan 23, 2006
no , not yet. I live in michigan and its freezing cold. Im waiting for a warm day, but i think im gonna buy the parts soon
Old Jan 23, 2006
CoupeStylz's Avatar
Si(R) killer # 1
It's my understanding that you can only buy the ball joint as part of the complete knuckle assembly for like 125 bucks or something.
Old Jan 23, 2006
cubanmike26's Avatar
How would you know when you need to replace it?
Old Jan 23, 2006
CoupeStylz's Avatar
Si(R) killer # 1
Look for a torn boot. once the boot is torn, the grease gets out and dirt gets in the joint. sooner or later the joint gets worn out and it makes a clunking sound when you go over bumps and uneven pavement.
Edit: you can drive like this for months or years but if the joint becomes so worn that it snaps while you're driving, you are looking at a 1300 dollar repair job for new everything inside the wheel well at best, and a dangerous crash at worst.
Old Jan 23, 2006
^^Hmm..that's interesting..thanks for that info..
I've been trying to find out about this cluking noise my car makes every time I go over bumps or bad roads..at first I thought it was the rod ends on my endlinks..but it sounds like it could be this joint thing..
CoupeStylz, how did your boot get torn? Are aour cars prone to this?
Old Jan 23, 2006
civic01vtec's Avatar
Jack your car up and take the wheels and shake them. If there is any free play, then the ball joint is bad.
Old Jan 23, 2006
^^Thanks
bsmiley
Apr 27, 2015 01:27 PM
El_Spic
Apr 23, 2015 03:14 PM
cdt12271
Apr 23, 2015 11:36 AM
veloce
Nov 10, 2001 01:19 PM
SILVERCASE
Sep 14, 2001 12:04 AM
