They're finally here!!!! sorry 56k
Old Jan 1, 2006
  #31
skratch_munkey's Avatar
skratch_munkey is an unknown quantity at this point
as soon as I get them on I'll let you all know how they ride.
Originally Posted by blouisgod
be a real man and use the spring install DIY
its not that hard really, you just need a breaker bar and a few sockets, maybe a spring compressor.
I plan on trying the DIY just gatta find the tools
Originally Posted by ragingSPAM
im putting my d specs on today!!! w00t im gonna take a **** load of pics
keep us posted on how it goes.
Originally Posted by digitaldemigod
Are those Eibach sportline springs?
Yes they are
Old Jan 2, 2006
  #32
Al Gore FTW's Avatar
jdmtytedoridori
Originally Posted by tuner04civic
im getting my whole set up done the 6th that includes this and progress front and rear sway bars(street use not autox) then im finally getting my rims after waiting like a year, then my look is nearly done and my stance will be the best
when you put the sways on, drive around and see how it feels...then take the 27mm front off and run with just the rear bar....its awesome.
Old Jan 2, 2006
  #33
tuner04civic's Avatar
spell check pwns you
yeah i just want to see how stable my car can be, months ago i drove and my car was starting to wabble, so i decided to go with sways and suspension. ill prob take it off to check but first i have spots im gonna try to test how the sway is and for understeer and oversteer. hopefullt it wont be bad anywhere on the road
Old Jan 2, 2006
  #34
dxray's Avatar
dxray is an unknown quantity at this point
Originally Posted by mrDFWmechanic
will everybody have to enlarge those bolt holes to 16mm or is it just for the newer civics, i have an 02
I have an 02 and I did not have to enlarge the holes. 01 and 02 civics do not have to be modified.
Old Jan 3, 2006
  #35
ragingSPAM's Avatar
I just burnt my tongue
well i have my rear d-specs on and the install went smooth as butter... as for the fronts i just installed my H&R springs in all four corners...i didnt have time and couldnt find a drill bit so i wasnt able to install the d-specs in the front but in the morning im gonna take it to a machine shop near where i live which should have the 16mm hardened steel countersink bits which is what is needed for the holes...after my trial and errors i decided to take the fronts to a shop to get machined out cuz they would know how to do it properly with a drill press and whatnot
Old Jan 3, 2006
  #36
So even the dspecs need to be drilled also? keep us posted when you get the fronts done.
Old Jan 3, 2006
  #37
ragingSPAM's Avatar
yea the d-specs are also for 01-02...most likley the same strut/housing that they used for the blues except different interior as in pistion, rod, and materials inside...sometime this week ill have them drill and installed
Old Jan 3, 2006
  #38
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
"16mm hardened steel countersink bits "
who said you have to use that?
Old Jan 3, 2006
  #39
ragingSPAM's Avatar
you dont have to but its the easiest to use if you have a hand drill not a drill press
Old Jan 3, 2006
  #40
SevenCyrus's Avatar
i see
Old Jan 4, 2006
  #41
mrDFWmechanic's Avatar
thanx for answering my question im about to order the same shocks from truehonda so i was just making sure
Old Jan 6, 2006
  #42
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Just wanted to let you guys know that we just posted a sale yesterday on the blues and one of the two sets is already gone. One more set available at $50 off the sale price!
Don't miss out on this one time deal.
Also, have a few neuspeed springs left at the old sale price.
Old Jan 7, 2006
  #43
Kairi's Avatar
Kairi is an unknown quantity at this point
word of advise: keep an eye on your bushings in the front control arms.
Old Jan 7, 2006
  #44
Why?
Old Jan 7, 2006
  #45
ragingSPAM's Avatar
my front bushings are torn on my 04 because the subframe was replaced because of an accident...they've been torn for over a year now and performance hasnt changed much
Old Jan 8, 2006
  #46
UPDATE
I finally got them on!!! Started @ 11 AM just finished @ 6 PM. Reason it took so long, the wife of the guy who installed them for me took his truck in the middle of the install. He needed his truck cause he didn't have a 16mm drill bit and needed to go find one. His wife went to the mall and took about 2 hours to get back.
Install costed me $100, I passed on the DIY cause I didn't have the necessary tools and space to do so.
All in all the ride is great, the back is a little higher than the front but I'll give it time to settle. The guy said I didn't need my rear camber kit, but I'll give it time if it feels like I do I'll put them on if not I'll sell them.
I'll get pics up tomorrow right after work and after I get it aligned. Thank you all for the info and tips you all provided. Rep will be passed.
Old Jan 8, 2006
  #47
ragingSPAM's Avatar
where did the guy get the 16mm drill bit? cuz i cant seem to find one anywhere...i've looked and looked and still havent found it...i needa get my front struts installed so i can get a damn reallignment
Old Jan 8, 2006
  #48
He didn't find one. He used a smaller size and just kept shaving till he got it to 16mm. I have faith in his work but I still have this side of me thats hoping he got it exactly. I don't want it falling off on me.
Old Jan 8, 2006
  #49
Hayz's Avatar
Can't wait to see the pics sounds like everything turned out good
Old Jan 8, 2006
  #50
goodtimes's Avatar
me to
Old Jan 8, 2006
  #51
SevenCyrus's Avatar
Ebay, they have them.
Old Jan 8, 2006
  #52
Ok, Just got the car realligned (the car was pulling to the right the day after) took an hour but its done. Now I'm starting to hear this rattling noise coming from the rear is this normal? Later on today i'm ganna check if anything is loose and get some pics up.
Old Jan 9, 2006
  #53
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
if u have a camber kit make sure the adjustment bolts are tight
Old Jan 9, 2006
  #54
Ok, fixed the rattling problem. Turns out when the car started to settle in the rear everything was pretty much got loose. I just needed to tighten the rear more. Now I need to go and put on my EM2 sticker and take some pics.
Old Jan 9, 2006
  #55
Now the pics
wheel gap
Now I need to get me some wheels
Old Jan 10, 2006
  #56
bhoy's Avatar
bhoy is an unknown quantity at this point
how much did u pay for cumber kit...?
Old Jan 10, 2006
  #57
I got them from Truehonda.com they're selling them for $169.
Old Jan 10, 2006
  #58
ragingSPAM's Avatar
haha i dunno how much cumber kits cost...i got mine off ebay for 60 bucks...just get the rears from ebay and the front bolts from truehonda
Old Jan 10, 2006
  #59
tarheel365's Avatar
looks nice...stock springs?
hows the ride? noticeable improvement over stock?
Old Jan 10, 2006
  #60
ragingSPAM's Avatar
^^ first post...there is a pic of the springs...i got my front d-specs installed today wow the ride is so stiff cuz i put them on hard...i need adjust it to a more comfortable ride...its so sweet and handling is like a champ...time to autocross!
