hows this for a budget suspension setup...
Old Dec 10, 2005
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
-Tokico blue HPs with stock springs
-progress rear sway bar
-possibly neuspeed upper front strut bar?
i hear the front sway is unneccesary b/c the front subframe is pretty solid.. true?
also, would new springs be a good idea? i get freaked out b/c i hear stories of peoples springs settling at different heights and all that...
Old Dec 10, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
what is your goal for the car and than we can tell you if that's a good setup or not.
Old Dec 10, 2005
01vic's Avatar
just want to make my daily driver more responsive
Old Dec 10, 2005
Shifty's Avatar
I think you should consider springs, settling of the springs are not a problem at all, and if you research and go with reputable companies you will have no issues.
I find that my eibach front sways are invaluable so i dunno, i guess its preference. If you do upgrade the front sway bar, i would also recommend doing the rear to balance the car.
You have a good start but i think that with springs you will get the most out of your set-up
Old Dec 10, 2005
Since you have a 01 i'd say your good with the Blues and get a rsx rear sway instead of the progress one. The upper front strut is a good idea as well.
WaryDriver
May 27, 2015 05:54 AM
ayoitzjulesdx98
May 13, 2015 08:31 PM
NYNE
Mar 8, 2002 01:31 AM
artychris
Nov 3, 2001 12:20 AM
Unomyname
Sep 25, 2001 11:09 PM
