What broke this?
Old Dec 1, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
What broke this?
hey guys, my front end has been creaking and moaning a lot lately and i decided to look, and try and figure out what it is. I have narrowed it down to 2 things, either my cai is rubbing on my battery mount (which i'm checking on my next day off) and also I looked underneath the fender and saw that #8 in the pic is completely worn out and on my passenger side, whenever jump on the door sill I can hear the shock sweak (I'm 200lbs) so i'm pretty sure thats blown to, but what the hell is #8?
Old Dec 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The bumpstop/dust boot
Old Dec 1, 2005
booba5185's Avatar
k, now i know what it is, but is it a must to have them? would it cause that noise?...etc.
Old Dec 1, 2005
skipbarber's Avatar
before my tein ss, i tore 3 of those, that is most likely NOT the source of your noises though.
Old Dec 1, 2005
booba5185's Avatar
it sounds more like a rattle, when i put the car into gear, the rattle get a lot worse, but it also get's really bad when i'm turning a lot in a parkin lot and all....i took my p/s pump off and looped the lines, so i'm wondering if i should drain the rack and put new\more fluid in
Old Dec 1, 2005
diskreet's Avatar
the bumpstop prevents you from bottoming out and screwing stuff up iirc
Old Dec 1, 2005
Jap-Euro Fusion
Its a must to have a bumpstop if you value your struts. Its not a must to have a dust boot. Shouldnt make any sort of mechanical sounding noise.
Check your CVs.
Old Dec 1, 2005
booba5185's Avatar
edit: saw boilermaker's post i dont think it's my cvs cuz it does it when the car is sitting still and i can hear it with the hood up, it's nowhere near those....
Old Dec 1, 2005
es2k2's Avatar
Proud to be a civic owner
i was told it could be the bearing.. i'm thinking getting the 01 upper mount + bearing for my 02 sedan ex... (i have a tein basic right now).. is there other thing i need to get to make the 01 upper mount fit in my car along with the basic?
Old Dec 2, 2005
Zzyzx's Avatar
Autocross Junky
um... you can hear it with the car stoped and the engine on?
if that is the case then it doens't sound like it could be coming form any part of the suspension to me. does the sound change as engine RPM's do? does it make noise only when you turn the steering wheel... ect ect ect.. the more specific as to when it makes the noise the more likely we will be able to find out what makes it.
Old Dec 2, 2005
booba5185's Avatar
it does it mostly when the engine is cold and at low rpms cuz the front ends vibrates more, it's definately coming from the driver side. Most of the time when it makes thes noise i'm parking or pulling out, meaning, i'm going slow and turning the whell all the way over....I'm thinkin that when i took out my power sterring there might not be enough fluid in the rack....any ideas on that?
Old Dec 2, 2005
Zzyzx's Avatar
Autocross Junky
Does it only happen when the car is moving, or does it make the sound when you are stoped and turning the wheel? Also, does it make the sound if the engine is off?
Old Dec 2, 2005
booba5185's Avatar
both, when i'm going through a parking lot with a lot of turning such as parking, avoiding speed bumps, going down different aisles, etc. I'm not so sure that it's somthing in the suspension, just in the steering part. I do think there is something wrong with my suspension, cuz the damn thing hits so easy, i'll get one other person in the car, crawl over a speed bump and the passenger side hits...hard. The rattling\moaning noise i'm talkin about is only happening when everything is cold, the engine rumbles more, so whatever is making this noise, makes it more.
Old Dec 2, 2005
h0nd4_r1c3r_X's Avatar
h0nd4_r1c3r_X has a little shameless behaviour in the past
when the dust cover of the struts get broken its good to replace it... since if u get sand or mud in there u fk up the strut...
Old Dec 2, 2005
Jap-Euro Fusion
There's a cleaner seal ring built into the strut, a little sand won't hurt anything, the strut takes care of it.
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
curaze
Sep 22, 2015 08:27 AM
