Question for Pro Kit installation
Old Nov 11, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Should the plastic around the spring be pushed all the way to the bottom of the spring before installing? Does it help it seat and not squeak or does it matter? Look at this pic, you can see the white/opaque plastic wraps about two rungs above the bottom of the spring.
Old Nov 11, 2005
italy273's Avatar
italy273 is an unknown quantity at this point
Pro-kit springs
I don't think so becasue those help reduce noice when the springs compress. I have the Pro-kit springs installed and mine were not pushed all the way down and they make no noise when i go over bumps or turn my wheel. I doesn't say anything about the rubber in the booklet that came with the springs.
Old Nov 11, 2005
robbclark1's Avatar
Retired suspension supermod.
You have to understand the concept of dead coils. Progressive springs have dead coils, meaning that they touch each other. The coil wrap goes between the top of the dead coils and the rest of the spring because that is where the coils will rub up against each other the most from compression and rebound. They are fine where they are.
Old Nov 14, 2005
dxray's Avatar
dxray is an unknown quantity at this point
Leave the plastic parts as is.
Old Nov 14, 2005
ramcosca's Avatar
Words on a User Title
If you do not know what it is, leave it as it came...
Old Nov 14, 2005
redem2's Avatar
redem2 has a spectacular aura aboutredem2 has a spectacular aura about
post some pictures!
izdman
May 19, 2015 03:43 PM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
CivicVTec
Nov 11, 2001 05:36 PM
SneakerPimp
Nov 3, 2001 10:57 AM
JeffSpeed21
Nov 3, 2001 10:32 AM
