Cleaning Tien SS CoilOver
Old Oct 19, 2005
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
Question Cleaning Tien SS CoilOver
First off, I searched and got over 10 pages of results.
Does anyone have a good way of cleaning the Tien Coil over so it can stay smooth when adjusting. I currently have Tien SS and I am about to raise the car for the winter again, and for it to be in the shop. I usually sprayed it with water and lubed it once last year. This year I didnt get around to doing that and I can see alot crap in the threads. Dont want to adjust with all that sitting in it.
Some one give me some tips on the easiest way to clean them up and lube it back up for a smooth adjustment.
Also while Im on the suspension topic, how do you check to be sure none are blown out,
Old Oct 19, 2005
Okay guess no one knows.
Old Oct 19, 2005
skipbarber's Avatar
i use a wide, thick bristled paintbrush to shake off all the debris and aerosol spray cleaner to get the stuck on grime off. Like a good degreaser. As far as the shocks being blown, its the same as it is with any other shock absorber, if it stops dampening it's blown. Bounciness is a clear sign, you can also do it by touch. Your shocks should be warm after driving, if they are cold, they arent doing their job and if they are hot there is too much friction.
Old Oct 19, 2005
Thanks for the info, sounds good enough for me. After the degreaser and its all cleaned up, do you put any type of lube on it, like wd-40 or something, or will that attract more dirt and grime
Old Oct 19, 2005
skipbarber's Avatar
nope, id try using a dry lube though, using oils will only attract more dirt.
Old Oct 19, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Toothbrush, soap and water. WD40 takes off corrosion, use anti-sieze or dry graphite to relube. If you move the perches to clean, re-align the car.
Old Oct 19, 2005
goodtimes's Avatar
http://www.7thgencivic.com/forums/sh...ver+love+clean
there you go. rep me please
Old Oct 20, 2005
Originally Posted by goodtimes
Good looking out.
Old Oct 20, 2005
goodtimes's Avatar
^ anytime anytime
SoslowEj666
Mar 8, 2016 01:10 AM
Misfit2613
Jul 30, 2015 09:49 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
