Which Struts? KYB or Tokico
Old Sep 13, 2005
llatikcuf's Avatar
llatikcuf is an unknown quantity at this point
02' Civic LX. Front Struts are shot. Not looking for anything special, but decided to come to the experts. Narrowed it down to two:
Tokico "Blues"
or
KYB GR-2
Not lowering the car, just looking for somthing that will last a long time.
Any help is appreciated,
TIA,
Nate
Old Sep 13, 2005
Zzyzx's Avatar
Autocross Junky
I'd go Tokico before KYB... but thats just a personal opinoin. either way they will be slightly stiffer then stock.
Old Sep 13, 2005
llatikcuf's Avatar
So I buy the strut online and take it to my local mechanic. Will I need to purchase anything else for the install?
TIA,
-Nate
Old Sep 13, 2005
Storm897's Avatar
Storm897 is an unknown quantity at this point
TIA,
-Nate
Im getting the struts installed at by mechanic this friday. Its costing me $100 for both front struts. I bought the KYB GR2's online at http://www.autopartswarehouse.com. Call them, they have it for $220 shipped.
I can tell you how it feels once they install it friday morning.
-Oren
Old Sep 13, 2005
JCiv03's Avatar
Does anyone know if Tokico or KYB ever plans on making struts for the 03+ civics with the 16 mm holes?
Old Sep 13, 2005
FALKEN's Avatar
Civicforums Junkie
Tokico
Old Sep 13, 2005
robbclark1's Avatar
Retired suspension supermod.
I believe tokico has some with 16mm mount holes. Call and ask.
Old Sep 13, 2005
llatikcuf's Avatar
-Oren
Let me know how it goes......
-n
Old Sep 13, 2005
Al Gore FTW's Avatar
jdmtytedoridori
drill the 14mm holes out with a step drill bit.
Old Sep 13, 2005
prccivic's Avatar
im alittle dissapointed in the Tokicos stiffness. They are much softer then i thought. Why not consider the KYB AGX's?
Old Sep 13, 2005
llatikcuf's Avatar
Expensive, don't need the adjustment. Been through 2 sets of stock struts, want something a little more durrable.
-nate
Old Sep 13, 2005
prccivic's Avatar
-nate
so u are not looking for a better ride.....u are just looking for a durable shock?
Old Sep 13, 2005
llatikcuf's Avatar
Both would be nice, but I don't want to pay $400 for two struts. I drive to work and school. Once a year I go on a road trip, ~1500 miles round trip. My car is nothing special - everything is stock. 45,000 miles on the car and been through 2 sets of struts.
-nate
Old Sep 15, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
jeebus 2 sets? in 45k you sound like boilermaker
Old Sep 15, 2005
honda860's Avatar
honda860 has a little shameless behaviour in the past
Tokico "Blues"
Old Sep 15, 2005
llatikcuf's Avatar
I don't know why? I don't drive hard, I slow down for bumps. My previous Saturn had struts with ~160,000 miles on them! When I sold it, they still had some life. WTF? I think Honda just bought bad struts for this model year. Some have said they were under specked. So here are my choices:
Pay $250 per each Honda strut (including install) at the dealership, plus alignment at 79.00
Total $579+tax
Or
Buy better struts online for about $120 per strut and have local mechanic install for ~$100 (for both - Guess on install price) +$49 alignment
Total $389+tax -- $190 cheaper and from what I hear, I won't have to change them for a long time.
-Nate
Old Sep 15, 2005
riversidetom's Avatar
riversidetom is an unknown quantity at this point
I'm also in the exact same boat as you Nate.
'01 Civic EX Sedan - still on the original struts. Totally stock setup still. probably need front and rear and don't really want to use Monroe (even though they have all the specials running lately)
Tokico Blues sound like the winner to me from all the stuff I've read. Now the question is where is the cheapest place either online or near Riverside, California to get those. Also, anyone here locally to Riverside/SoCal want to make a few extra bucks by putting them on for me?
Also, I think my CV joint front left is starting to go. Is there any advantage to get the struts fixed before the CV joint or vice versa? Should I try to get them fixed at the same time?
Old Sep 15, 2005
llatikcuf's Avatar
"Thump" when you turn the wheel to one side? Mine did the same thing, CV joint was good - Just a loose tie rod (or that's what the dealership said) tightened it down and it went away.
Good luck man.
-Nate
Old Sep 15, 2005
shroomster's Avatar
Total $579+tax
Or
-Nate
you just answered your own Q search around on here usually a good deal for tokicos (all4) can be had for like 400 and you wont worry about having to change backs later on either....
Old Sep 15, 2005
shroomster's Avatar
treat your suspension like its a full set of tires that are going bald on you...or rather wearing out on you from the up and down movement....best to do everything at once if you can afford it cuz its cheaper to do it all at once then having a problem rear its head because you wanted to save a few bux now
Old Sep 15, 2005
i wouldn't say it's a "thump" as much as it is a "clicking". not constant though. I don't have to be turning to hear it either. somewhat random. maybe more than 1 issue going on? damn I need a local Honda guru to look at this!
edit: is this a good deal for a full set of Tokico blues? http://www.streetlevelperformance.co...ull%20Set.html
Old Sep 15, 2005
shroomster's Avatar
good range is between 290 and 375 75-100 a piece
Old Sep 15, 2005
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
I found that www.tirerack.com, just checked website and they raised their price--shiet, had the best price on KYB AGX by quite a bit and they sell tokico, I got a set of AGX locally and installed myself. They are great on the #1 setting. I love them. I also had KYB GR2 in another honda, they were too light. I wish i had experience with the tokico so i knew how they compared to KYB. <<2cents>>
Old Sep 15, 2005
Here you go, KYB AGX, 127 * 2, 175 * 2 = $604.00 == wtf? hmm... on second thought thats too much...
http://performance.speedycarparts.co...329&brandid=77
Old Sep 16, 2005
llatikcuf's Avatar
What do you mean by too light? Compress too easy? How do they compair to factory?
-Nate
Old Sep 16, 2005
-Nate
They were MUCH better than factory, but in an extreme turn they would sway too much. And maybe that is because the vehicle had no sway bars! It was a complete stock LX. I forgot about that. Then really in that case, I think the GR2 were superb. They will make you feel like you are driving a cadilac. really, if you are into a smooth ride, these shocks provide that.
Old Sep 17, 2005
prccivic's Avatar
-Nate
they are alittle stiffer then factory...but if u are looking for an aggressive ride, then i say AGX's
Old Sep 18, 2005
Storm897's Avatar
Just got my car back yesterday morning. I've been procrastinating on changing out the blown struts for such a long time. Now that my struts are working again I can certainly feel less ounce whenever I go over a pothole and speed bump. These are slightly stiffer then stock but still provide a comfortable ride. I would recommend GR-2's.
Old Sep 18, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
Is all the rattling gone from your fronts, i am getting the same noises, but mine is dropped on prokit i was considering the GR-2
Old Sep 18, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I had that same problem as you, I'm on my third set of shocks.. They were all covered under warranty but this is starting to get a little ridiculous. I'm looking at the AGXs as well but they do seem a bit over priced?
