Help me pick a new suspension
Old Aug 20, 2005
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
First let me say I am looking for a top quality app that will not give me problems in the long run. I am only looking to be lowered about 2" on a daily driven sedan. I will rarely ever go to the track.
Now, I am trying to decide between:
Hayame Full Coilovers NEW V.3
B&G Full Coilovers S3
Tein SS Coilover
Tein Basic Coilovers
I don't want to spend the money to get options I don't need but I don't want to end up with crap either.
Old Aug 20, 2005
streetglower's Avatar
please search. they are plenty of reviews on all of these suspenion setups.
Old Aug 20, 2005
HEBEGEBZ's Avatar
yes, i know this and i have. That is how I narrowed my choices. Please don't treat me like a noob. I have been around since 2001 (back when post counts were not kept) and I don't post a lot. Only when I need help with something or think I can help will I post. I mostly just read. All I want to know is which one do you think is a better app for my car is all. In my searching I found all of them are good.
Old Aug 23, 2005
obguam's Avatar
obguam is an unknown quantity at this point
I'm also "in the market" for new suspension, and have read a million threads. I'm leaning towards Tein SS or Basics. Reasons: Teins seem to have received highest praise over past 2 years for both design and quality. B&G's are top quality and offer a lower drop (which I don't want). But the SS offer maximum adjustablility, and EDFC capability. Just my preference, and way of bumping for more opinions.
Old Aug 23, 2005
Zzyzx's Avatar
Autocross Junky
Well what are your needs/wants out of the suspension? Ride quality over performance or vice versa?
Old Aug 23, 2005
HEBEGEBZ's Avatar
I am hoping to find a nice middle ground. I know nothing is going to ride like stock but I also don't want to crazy the hell out of my girl everytime i hit a little bump. Like i said little to no track use. I guess what I am looking for is a high quality suspension setup that will give me a nice drop (2-3"), a nice "sporty" ride and most importantly will last.
Old Aug 23, 2005
HEBEGEBZ's Avatar
I think only the Tein Flex has the EDFC option.
Old Aug 23, 2005
Zzyzx's Avatar
Autocross Junky
EDFC is a $400 Gimic... Really, how often do you see your self changing the damper rate on your car?
If you want improved performance with a good ride, I'd recomend Not getting a pre-built coilover, but rather a good Progressive spring with a good damper. It'll be cheeper and give you just as good, if not better performance as any of the "coilovers" you've listed. only down side is that you wont beable to impress your friends by saying you have Tein "Coilovers".
Old Aug 23, 2005
HEBEGEBZ's Avatar
i have read people who do this have problems with getting the springs and dampers to mesh well.
Old Aug 23, 2005
Zzyzx's Avatar
Autocross Junky
Thats because people tend to use springs with OEM dampers.
Old Aug 23, 2005
HEBEGEBZ's Avatar
so there is no advantage to the setup I listed about and the progressive spring setup you mentioned. What dampers should i use, Koni?
Old Aug 23, 2005
Zzyzx's Avatar
Autocross Junky
The only real advantage a "coilover" would have over a spring + shock combo would be in the ability to adjust ride height. If that doenst matter to you then I see little reason on spending the Extra money.
For street use with a progressive spring, Tokico Blues (HP) or Tokico D-Spec if you want to have adjustible dampers. You could do KYB AGX's, but I've seen some shock dynos of them and they have limited adjustibility, and tend to have a pretty stiff bump setting, Tokico's however are known to be on the "softer" side of high performance dampers, so you'd probably get a better ride out of them. Konis are great too, one of the best really (For the $$) but they are harder to install then the other listed dampers.
Old Aug 23, 2005
jayrck81's Avatar
rocking the dx w/ vtec
jayrck81 is an unknown quantity at this point
I have eibach sportlines with kyb adjustable shocks, ride is smooth and its pretty low, I heard that koni yellows are better but imo i think they are just a lot more expensive. As far as springs go i think eibach makes some of the best springs on the market.
Old Aug 23, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
tein ss
Old Aug 23, 2005
Zzyzx's Avatar
Autocross Junky
I don't understand the import worlds obsession with pre built coilovers....
Old Aug 23, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
It's all about bragging right. In reality, once a part is installed, it'll never be messed with again until it breaks.
Old Aug 23, 2005
tsyslick's Avatar
tsyslick is an unknown quantity at this point
i also have a sedan and i wouldn't recommend coilovers. . i mean they could be adjusted and all that but in about 6 months or so you'll start hearing things underneath your car, i only have spring setup and i'm happy with with it, but i guess whatever floats your boat.
NEUSPEED SPORT SPRINGS
Old Aug 23, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
if ur gonna spend that kind of moeny, why don't u get the new megan coilover kit for over cars, it got great reviews...but from your list i would go with tein all the way
Old Aug 23, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
why wouldnt you want coilovers for a sedan, i would think coilovers would be better for a sedan?
Old Aug 24, 2005
HEBEGEBZ's Avatar
One thing is with coilovers if you start to sag you can adjust. You can't do that with springs.
Old Aug 24, 2005
obguam's Avatar
I like Tein SS coilovers because they offer a professionally designed, properly matched and well constructed spring/shock/strut set up. And flexibility. "TEIN has developed advanced technology to design the shell case and stroke to bring out the full potential of your vehicle. These features of the TEIN Super Street Damper kit were designed with greater performance to satisfy all your driving demands. This high performance damper can be used for weekend racing and/or daily driving. The discomfort caused by uneven roads or bumps are eliminated on daily street use. For race use, the ride height adjustable system enables you to adjust ride height and 16 levels of damping force. In other words, you can set your vehicle to meet all situations!"
Of course, I'm not going to change ride height every month. I would however like to be able make adjustments to height, have to ability to corner weight, and play around with damper settings until I get it just right.
Old Aug 24, 2005
jackburton's Avatar
are the basics worth buying?
Old Aug 24, 2005
Zzyzx's Avatar
Autocross Junky
the only thing the SS has over the Basics is the adjustible damper... so, Do you plan on tweaking the dampers? if not, then the basic will work for you. (most people have no idea what or how they are tweaking the handling with dampers any way.)
Old Aug 24, 2005
HEBEGEBZ's Avatar
what level are the basics set to then (1-16)? Do you know?
Old Aug 24, 2005
HEBEGEBZ's Avatar
hardest, softest in the middle or what?
Old Aug 24, 2005
Zzyzx's Avatar
Autocross Junky
Not sure, but does it really matter? other then maybe having the ablitiy to alter ride quality, do you really know/understand what else you are tweaking by altering the damper rates?
Brad Andrew
Sep 8, 2015 08:25 PM
Brad Andrew
Sep 8, 2015 08:22 PM
