I've read through the forums &still searching.......
Old Aug 1, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Question I've read through the forums &still searching.......
for an answer: do you purchase a camber kit only when you lower the civ? Or is it necessary if you are lowering the car with eibach prolines and stationary struts/shocks?
Or is it just better to get someone who knows (professional) how to align with aftermarket suspension parts?
Update: as of current I have decided to go with Eibach proline springs, I'm still looking for shocks and struts thinking Koni but i'm not sure I want adjustable
Old Aug 1, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
again u dont NEED it when u lower it, but its recomended. and u dont need it with stock springs, but u need it with aftermarket springs, the shock doesnt have alot to do with the camber.
Old Aug 2, 2005
Da1lyDr1ver's Avatar
just get one, you'll be sorry if you didnt in the end
Old Aug 2, 2005
VTECTypeR's Avatar
Boilermaker is gonna pimp slap you now hehehe
Old Aug 2, 2005
streetglower's Avatar
No you dont only purchase a camber kit when lowering. You purchase one whenever you cant get your alignment angles back within factory specs. I am not lowered and I have them. Now if you are going to lower your car, you might as well do it the right way and spend the $130 or so for the camber kit. Dont be one of those loser people who drive a wanna be street car with tires half bald from really negative camber. do it the correct way. In the long run you will save in buying tires.
It doesnt matter how good someone is at doing alignments, if it is out of specs, it is out of specs, and there is nothing that will bring it back in no matter what the tech does. Now it could be a bent part that is causing it to be out of spec, but other times, normal wear takes effect.
And dont tell me you did search and didnt find anything because at the top of the suspension forum there is this thread
http://www.7thgencivic.com/forums/sh...d.php?t=200089
And if you type in camber kits in the search bar, it pulls up thousands of threads about camber kits, most of which have been locked because of too many being started.
Old Aug 2, 2005
robbclark1's Avatar
Retired suspension supermod.
Streetglower said it best
It is Eibach ProKit, not proline. If you car is a daily driver and you are lowering for appearance, then get the tokico blues.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
werdnahall
May 17, 2015 11:37 AM
crowtoo
May 11, 2015 06:50 PM
bsmiley
Apr 27, 2015 01:27 PM
Dorval Andre
Apr 20, 2015 05:34 PM
