Sportline/koni or Tein Full coilovers?
Old Jul 12, 2005
rickyhermida's Avatar
rickyhermida is an unknown quantity at this point
I have Sportline Springs with koni yellows
I want to know if Tein Full Coilovers are a better suspension
thanks
Old Jul 12, 2005
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
Teins All The Way Buddy Hands Down!!!!
Old Jul 12, 2005
Zzyzx's Avatar
Autocross Junky
Not even close, But then it really depends on what you are looking for out of your suspension.
There are several things about Tein that make them a poorer performance damper then Konis. First one being that you adjust both bump and rebound with the teins, where Konis only adjust Rebound. now the problem with teins isnt that you adjust bump and rebound, the problem is that you adjust them at the same time with the same ****... meaning, for tuning handling, you end up having to comprimise between the desired corner entry/exit balance of the car with Rebound, and the bump aborbing propertys of the bump side.... not all that great for handling. Then there the part about Konis haveing a much wider range of adjustment... ect ect ect...
any way, if you were to tie those Konis in with the proper spring, such as ground controls (maybe do a little custom spring rate) then you'd have a setup that could easily out perform just about any Pre-built coilover could offer. It may take a little thinking and tuning on your part, but in the long run you'd have a better performing car.
Old Jul 12, 2005
burke420's Avatar
The World Is Yours!
id say some koni's with ground control or skunk2's rather than a full setup. since u can use leftover $$$ to buy strut bars and tie bars. IMO
Old Jul 12, 2005
burke420's Avatar
The World Is Yours!
and the tein's wont let you go as low as ground control or skunk2 wood i think
Old Jul 12, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
To Low = Bad
Old Jul 13, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
^^ but looks sick as fvck!
SoslowEj666
Mar 8, 2016 01:10 AM
Misfit2613
Jul 30, 2015 09:49 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
