Rear lower than Front
Old Jun 9, 2005
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
Sup guys,
I got a problem. As the title says, the rear on my sedan is lower than the front. About 2 weeks ago I was at a tech-meet and we threw on some new Tein S-Tek's on my ride, and the drop is only supposed to be 1.3 in the front and 1.4 in the back. Even before I left I noticed the back was sagging a bit, and now it looks significantly lower than the front. I don't have anything heavy in the trunk... does anyone know what the problem might be? Shocks?
And yes, these springs were made the the sedan too. Caucasian.Asian has the same springs as me and he doesn't have the same drop on his sedan...
Thanks!
Old Jun 9, 2005
gh0st's Avatar
TAQUITOS!!!!
are you on oem shocks?...maybe its the damn roads in stockton
Old Jun 9, 2005
ZapThyCat's Avatar
My shocks are stock, yes... but I have no clue why they'd be drop so much, and only in the back...:-/
Old Jun 9, 2005
slicksivik's Avatar
maybe ur shocks are blown and the rear is usually lower then the front. like obvious lower. if u want em even, u gotta get coilovers.
Old Jun 9, 2005
slicksivik's Avatar
oh u probably noticed ur right side is higher then ur left too. i hate that, cuz its so obvious in my car cuz one side is dumped to the tire and the other is like half an inch higher, but oh well, i can lower it if need be.
Old Jun 9, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
uhh, did you use camber kit? lowering springs without a camber kit and alignment will cause your tires to slant so it will be lower.
Old Jun 9, 2005
im stock now! T.T
if u havent already get a camber kit installed then get an alignment fromt a reputable place immediately. Your tires will last 1 month max with lowering springs and no camber etc.
Old Jun 9, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
most springs are made for coupe.... I dont recall Tein differentiating between sedan and coupe springs.... however, Neuspeed does with their sport springs.
Old Jun 9, 2005
es2k2's Avatar
Proud to be a civic owner
i have tein s tech too and the rear sags... (not sure if it's because i have a 12" polk sub)
neuspeed and coilover will not have this problem..
so i'm tempting to get a tein basic coilover at the end of the month...
Old Jun 9, 2005
Rennen's Avatar
New Mod on the Block
i gotta disagree. i've had my springs on for 3 months now with no camber kit and i still have plenty of tread left.
Old Jun 9, 2005
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Tein S-Techs are known for sagging rear springs, even on 6th gens they sag. There really is nothing you can do about it other than get a new setup.
Old Jun 9, 2005
jttegx's Avatar
OMNES AD UNUM
are the part numbers the same on your springs and caucasian_asian's ?
^that is true. seems like the tein s-techs were meant for coupes as most aftermarket springs on the market. when its dropped on OEM shocks, the sagging would be worse as the stock shocks are pretty soft/firm compared to aftermarket. flotsamm had the tein s-tech springs on his coupe on stock shocks i believe, and his ride height was evened out.
did caucasin_asian (seller?) remove his spare tire or anything for weight reduction?
Old Jun 10, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Just posting to confirm that Tein does not specify a different spring for the coupe and sedan.
Old Jun 10, 2005
dru106's Avatar
ThE CoRRupToR
Originally Posted by zapthycat
Sup guys,
Thanks!
1.3 front and 1.4 rear?? That spring is deffinatly for a coupe!! I know that the stock height between a coupe and a sedan is that the sedan's front is higher than the rear and vise versa
Old Jun 10, 2005
dj02's Avatar
you my friend have no idea what your talking about! please stop posting wrong information.
anywho do you have a 4dr or 2dr? the rear springs are diffrent for 4dr's and 2dr's make sure you have the right springs for the right model. it can also be if you have blown rear shocks.
Old Jun 10, 2005
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
My tires lasted a year before I got camber kits...LOL
Old Jun 11, 2005
eye_see_you's Avatar
let the devil out
you have a system in the back? I had the 2.75 inch drop due to my system in the rear on stock shocks. after I took the box out it raised back up some. I upgraded to Tokico's and all has been gravy since
Old Jun 11, 2005
ZapThyCat's Avatar
I don't have an actual system in the truck... I have a bunch of stuff there, but nothing heavy at all.
In any case, it's strange. At the tech day today we put some spacers inbetween the springs, that was supposed to lift if 1.5. It didn't, but it lifted it enough so that it's not a real big problem anymore....
Thanks anyways guys...!
Old Jun 13, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
i been lowerd for 3 months no camber kit and my tires are fine thay havent even worn any
rtachs
Jul 16, 2015 05:32 PM
Mercilus
Jun 7, 2015 10:00 PM
vtec_concept
May 24, 2015 10:27 AM
bsmiley
Apr 27, 2015 01:27 PM
