My Springs Are Popping????
Yesterday Me And A Friend Of Mine Installed Some Springs On My 03 Ex. Everything Thing Went Ok Until We Pu It Down And Now When U Turn The Wheel The Sprngs Pop. Any Ideas?
Yes, I just went trhough this, you can probably see my post from a couple weeks ago around here somewhere. It ended up being this: When you took off that metal plate on the upper part of your frount struts, you didn't put the bearing (it's actually a rubber bushing) back in. I went to great lengths to try and figure this out and finally did. By the way, it was the same car, 03 EX.
Mine pop...But they'll pop for a week straight (turns) then all of a sudden it stops for a week. Its annoying, but its also a good conversation piece when people ride with me...
poppin springs
i have the eibach prokit, it took a couple miles driving on them for them to set in place, i noticed the popping, i made sure everything was tight, then i went down some residential streets and threw the car around, the spring settled and they have been quiet since. i would reccomend turning a few sharp turns a little faster than normal. It worked for me.
Originally Posted by x25xtalife
Nah. Its There Everything Is On The Strut That Is Supposed To Be. I Work At Honda And Had A Tech Do It So Im Pretty Sure We Put Everyhting Back On
One of the most common problems that cause popping noises are:
- The spring isnt seated correctly in the top perch'es rubber isolator
- The bearing is worn out or needs repacking
- The top mount isnt seated/installed correctly in the tower
- The tie rod end is defective
- The spring is coil binding
- The top strut nut isnt tightened enough
Just because everything is installed doesnt mean it was done correctly. The tech should of known you dont need to mark everything. You just line up the arrows on the top mount and upper spring perch with the hole on the lower perch like this:
Then all you do is make sure nothing moves when you install the whole assembly. Did you leave the coil wrap(rubberized tubing that comes factory installed) on?
my springs pop as well....mine poped when i first put it down then they stopped and now they just kinda come and go as they please....i am going to try and repack the berings today.... and see...... ill let you know if the problem is fixed or if i figure somthing out...
Got it......when i took em out the berings were greased but kinda hard to move....so what i did was greased the Sht out of them....in the bering and on top....i put it down and now not one pop the entire time....hope this helps....
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
TheRiddicles
Sep 21, 2015 01:28 AM
