dc sports strut bar problem
Old Apr 29, 2005
bluevtec's Avatar
bluevtec is an unknown quantity at this point
I just bougt a dc sports strut bar that goes around the aem cold air intake. I've got a 02 civic coupe. The driver side was easy but I'm having problems putting the passenger brace on. My friend told me that it had taken him three hours for him to get on. I called Dc sports and they told me to jack the car up and it loosens the suspension. I've got ground control coilovers. It is a pain in the ***. Is there a technique anyone knows of to install upper strut brace?
Old Apr 30, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
wow, only took 5 mins to put mine on. you need to loosen the bolt that connects the strut mount to the bar then tighten it back once you've got it on the strut.
Old Apr 30, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
^what he said. make sure everything is loose when you install it, then tighten after.
Old Apr 30, 2005
bluevtec's Avatar
Yeah I'm trying to put the black mounts on first then connect the strut brace, but its just the passenger side that is a pain in the ***. I'll get one going and then try to get the others but it seems that it is off just by half and inch.
Old Apr 30, 2005
Xenin's Avatar
put the passenger side on first, then loosen the bolt that connects the actual bar to the black metal part, then fit it on the driver side.
Old Apr 30, 2005
bluevtec's Avatar
but I cannot even get the passenger side on. it seems that it is such a tight fit.
Old Apr 30, 2005
Xenin's Avatar
did you loosen all the bolts on the bar so that the mounts can move around?
Old Apr 30, 2005
bluevtec's Avatar
yeah i've taken the whole bar apart. I'm trying to put the black mounts on first, then bolt evrything down, and then put the bar on and tighten that. Its just that the passenger black mount is not going over all three screws
SugarRay
Dec 13, 2001 09:58 AM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
